Access Hole Cover Installation / Pics
Don Boardman
Post by Don Boardman » Sat Feb 18, 2012 9:40 am
Hi All,
Randy and I went a round and a round on how to install the small access hole
covers. (and vertical fin fairing) Nut plates are the norm. The problem is
that with the skins so thin countersinking is marginal at best. MAM supplied
sheet metal screws ... ^$#&^%(*&.
We finally settled on Flush Keyed Rivnuts for #6 ss screws.
You drill a 3/16 hole, dimple the hole or countersink in thicker stock, file
a small notch in the side of the hole to catch the key of the rivnut, insert
the rivnut and squeeze. Once you've done a few you get the feel for how hard
to squeeze so you set the rivnut well but not too hard as to damage the
threads. If you mess up they are easy to drill out and replace.
Rivnuts are not as robust as nutplates but with care for a good installation
and normal care in installing screws they do quite well. I installed herds
of the non countersunk ones on my CH701 and after 10 condition inspections
never had a single problem.
I have posted some pictures showing results.
Hope this will help someone,
Don B.
Post by Drew Dalgleish » Sat Feb 18, 2012 9:40 am
At 12:31 AM 11/15/2004 -0500, you wrote:
Hi All,
Don B.
I used a bunch of unkeyed ones doing my float instalation since it was
impossible to get in behind where the fasteners had to go and install
nutplates. I put a dab of sikaflex on each one and I've removed the floats
twice without having any of them spin. I bought my rivnuts locally at a
fastener store and made my own tool for installing them. I used a long bolt
the right thread and turned down the shank with a file and my drill press
until it would fit my hand rivet puller.
bransom
Post by bransom » Sat Feb 18, 2012 9:40 am
Don,
Thanks a lot --- yes, this helps me, for one. Having not built a metal
airplane I barely know what a nutplate vs rivnut is, nor whatever other
options there are for these kinds of things. Glad to know too that others go
round and round for seemingly small things such as this!
Drew, if you ever get a chance, I'd be curious to see a picture of your home-
made rivnut install tool. And, Wayne, if your listening on this one, I've
also thought it would be helpful to see a picture of your home-made edge
roller you once described.
...for the verbally challenged :)
-Ben /496R
On 11/14/2004 8:31 PM, DBOARDM3@TWCNY.RR.COM wrote to REBEL-BUILDERS:
Hi All,
Don B.
Post by Wayne G. O'Shea » Sat Feb 18, 2012 9:40 am
Ben...will see if I can fit some picture taking into the schedule! Wayne
Sent: Monday, November 15, 2004 2:42 PM
Subject: RE: Access Hole Cover Installation / Pics
Don,
go
home-
-Ben /496R
Hi All,
hole
is
supplied
file
insert
hard
installation
herds
inspections
Don B.
I'll try to get that for you soon Ben but I'm kinda digital camera challenged
At 10:42 AM 11/15/2004 -0900, you wrote:
Don,
go
-Ben /496R
Hi All,
hole
supplied
file
insert
hard
installation
Don B.
Sent two pics of the edge roller Ben...but not sure if you'll get them since
this is the only address I have for you thru dcsol.com Wayne
Don,
go
home-
-Ben /496R
Hi All,
hole
is
supplied
file
insert
hard
installation
herds
inspections
Don B.
Post by Ken » Sat Feb 18, 2012 9:46 am
Another option might be dimpled nutplates for thin aluminum. You dimple
the 3/32 rivet holes instead of countersinking. I usually stock up at
Oshkosh and find them very useful even on 0.020. I guess I have an
aversion to keyed rivnuts in case a crack starts at the keyway. I've
tried the non-keyed rivnuts from Spruce though and will admit that they
work quite well compared to the junk ones that are sold locally by
Princess Auto.
Don Boardman wrote:
Hi All,
Don B.
