Aren't the Rebel & Moose tailwheel assemblies one and the same?
While the AK Bushwheel tailwheel assembly (
http://www.akbushwheel.com/TundraTailwheel.html ) would be great if I
did most landings off-pavement, I, unfortunately, have to say 80% of my
landings are on pavement. Hence, I'm looking for a larger footprint to
reduce rolling resistance for the 20% of the time I'm on grass/sand.
The MAM (Moose) tailwheel assembly just doesn't seem to be very robust
compared to a Scott or to a XPMODS tailwheel (
http://www.xpmods.com/tailwheels/default.asp ). That doesn't mean the
MAM (Moose) tailwheel isn't Ok for most applications; I just perceive
the tailwheel as a particularly critical component; I want to make sure
I have the best (cost/benefit) one available.
rickhm@comcast.net
Sent: Friday, November 12, 2004 3:44 PM
Subject: Re: Moose tailwheel stinger
I have read of problems with the Rebel tail wheel from MAM. Two
questions. 1) has the moose/2500 tail wheel presented a problem,
demonstrated issues, etc. 2) Is there reason to believe it will?
Rick Muller
SR70
Rebel vs Moose tailwheel
No Rebel tail wheel and Moose tailwheel or two entirely different animals.
Rebel is just a 6" solid rubber tire and a much lighter fork/pivot assembly
than the one I have for the SR.
Sent: Saturday, November 13, 2004 12:00 PM
Subject: Rebel vs Moose tailwheel
rickhm@comcast.net
Rick Muller
SR70
In May of 2002 when Mike Kimball and I flew down to Anchorage to fly the MAM
demonstrator, they had it outfitted with a tailwheel assembly that used the
nosewheel off of an Elite. Does anybody know what came of that experiment?
Sent: Saturday, November 13, 2004 8:00 AM
rickhm@comcast.net
Rick Muller
SR70
Supposedly, one can still get that Elite nosewheel / tailwheel. I
haven't seen one or talked to anyone that has any insight on hot robust
it is...
Sent: Saturday, November 13, 2004 4:33 PM
Subject: Re: Rebel vs Moose tailwheel
MAM
experiment?
it is...
MAM
experiment?
my landings are on pavement. Hence, I'm looking for a larger
footprint to reduce rolling resistance for the 20% of the time I'm on
grass/sand.
sure I have the best (cost/benefit) one available.
rickhm@comcast.net
Rick Muller
SR70
I have the new tailwheel and it looks robust. The plan is to pull the
amphibs tomorrow and install the conventional gear and the new tail wheel
this week. I plan a gusset where the stinger mounts in the channel brackets,
that means an access hole in the tail cone. I'll keep you posted, but the
plane will be down for a week or two.
Al
Moose, N526AP
Sent: Saturday, November 13, 2004 6:16 PM
Subject: RE: Rebel vs Moose tailwheel
Al
Moose, N526AP
it is...
MAM
experiment?
grass/sand.
The MAM (Moose) tailwheel assembly just doesn't seem to be very robustcompared to a Scott or to a XPMODS tailwheel (
http://www.xpmods.com/tailwheels/default.asp ). That doesn't mean theMAM (Moose) tailwheel isn't Ok for most applications; I just perceive
rickhm@comcast.net
Rick Muller
SR70
