cylinders
cylinders
Post by Mike Davis » Fri Feb 17, 2012 5:26 pm
Received: from [137.186.224.219] (helo=ms01-219.tor.istar.ca)
by mail4.toronto.istar.net with smtp (Exim 1.92 #2)
for murphy-rebel@dcsol.com
id 11HFYv-0002Kg-00; Wed, 18 Aug 1999 19:56:09 -0400
Mime-Version: 1.0
To: <murphy-rebel@dcsol.com> (Murphy Rebel Builders List)
Subject: Re: cylinders
Message-Id: <E11HFYv-0002Kg-00@mail4.toronto.istar.net>
Date: Wed, 18 Aug 1999 19:56:09 -0400
Sorry to hear you had problems, Bill. I hear this is fairly common with
chrome bores - but a hone job sometimes lets you try again, and often
succeeds .....
There have been problems with the Cermichrome process, too, but it
seems like a better way to go ... The Nikasil cylinders on the 912
work GREAT !
--------------------------orig.--------------------------------------------
At 12:42 PM 8/17/99 EDT, you wrote:
I AM INTERESTED IN WHAT PARTS YOU HAVE TO OFFER FOR A REBEL.
MINE HAS FLOWN 5 TIMES, BUT IT WAS BLOWING A LOT OF OIL. WE REMOVED THE
CYLINDERS AND FOUND THAT THE RINGS WERE NOT SEATING ON THE CHROME BORES.
BILL NEWKIRK, #376
cylinders
Received: from BILNEWKIRK@aol.com
by imo22.mx.aol.com (mail_out_v22.4.) id bYPSa06597 (4113)
for <murphy-rebel@dcsol.com>; Fri, 20 Aug 1999 18:23:44 -0400 (EDT)
Message-ID: <a38066ce.24ef2f70@aol.com>
Date: Fri, 20 Aug 1999 18:23:44 EDT
MIME-Version: 1.0
X-Mailer: AOL 3.0 for Windows 95 sub 76
BOB, THANKS FOR YOUR SYMPATHY.
I SERIOUSLY CONSIDERED USING A 912 BEFORE I SETTLED ON THE O-290, BUT D.
MURPHY TOLD ME THAT I WOULD BE VERY UNHAPPY WITH THE PERFORMANCE HERE IN THE
WESTERN U.S. NOW I WONDER, PARTICULARLY WHEN I HEAR YOU SPEAK ABOUT THE 912
IN SUCH GLOWING TERMS.
BY THE WAY, I WAS BORN IN WALLACEBURG AND RAISED IN LONDON BUT HAVE BEEN IN
CALIF. FOR MANY YEARS.
BILL NEWKIRK
cylinders
Received: from default (AS52-17-65.cas-kit.golden.net [209.183.131.65])
by phantom.golden.net (8.9.3/8.9.3) with SMTP id TAA22487
for <murphy-rebel@dcsol.com>; Fri, 20 Aug 1999 19:29:50 -0400 (EDT)
Message-ID: <002401beeb64$96af9960$4183b7d1@default>
Date: Fri, 20 Aug 1999 19:34:42 -0400
MIME-Version: 1.0
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
X-Priority: 3
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook Express 4.72.3110.1
X-MimeOLE: Produced By Microsoft MimeOLE V4.72.3110.3
bill the nikasil bob p. mentioned on the 912, is the same process =
different name offered by engine components inc (ECI) 1-800-324-2359 =
called cermiNil,
peter k.
SR003=20
To: murphy-rebel@dcsol.com <murphy-rebel@dcsol.com>
Date: Friday, August 20, 1999 6:24 PM
I SERIOUSLY CONSIDERED USING A 912 BEFORE I SETTLED ON THE O-290, BUT =
D.=20
MURPHY TOLD ME THAT I WOULD BE VERY UNHAPPY WITH THE PERFORMANCE HERE =
IN THE=20
WESTERN U.S. NOW I WONDER, PARTICULARLY WHEN I HEAR YOU SPEAK ABOUT =
THE 912=20
BY THE WAY, I WAS BORN IN WALLACEBURG AND RAISED IN LONDON BUT HAVE =
BEEN IN=20
BILL NEWKIRK
cylinders
Received: from [137.186.224.21] (helo=ms01-21.tor.istar.ca)
id 11I112-0003eQ-00; Fri, 20 Aug 1999 22:36:20 -0400
Mime-Version: 1.0
Message-Id: <E11I112-0003eQ-00@mail4.toronto.istar.net>
Date: Fri, 20 Aug 1999 22:36:20 -0400
Now that the 100 HP. 912-S is available, it might be a reasonable
choice .... We've certainly been a lot of places with the old 912,
lugging a lot of gear ! :-)
London's only about 90 miles away !! Small world !!! One of these
years, I'd like to get out to California - we've been to Florida often,
and the west coast of Canada, and I've flown a Rebel up to Kuujuaq, near
the Arctic, but have never had a chance to visit the south-west - maybe
one day !!
Hope honing the cylinders will do the trick !
....bobp
----------------------------orig.------------------------------------------
THE
912
BILL NEWKIRK
cylinders
Received: from AzAlexR@aol.com
by imo29.mx.aol.com (mail_out_v22.4.) id 5NVAa01987 (15548);
Fri, 20 Aug 1999 22:53:50 -0400 (EDT)
Message-ID: <5734fea1.24ef6ebe@aol.com>
Date: Fri, 20 Aug 1999 22:53:50 EDT
To: Bob Patterson <bob.patterson@canrem.com>,
MIME-Version: 1.0
X-Mailer: AOL NetMail version 2.0
Bill & Bob
In regards to your comments and problems with oil consumption. I have used
chrome cyls. on
L-0360 engs. and overhauled several engs. using re-chromed or just honed and
etched barrels.
Not to be confused with "cermichrome" cyls. I have found the best way to
break in new cyls.
was to run the eng. hard, that is, high man. press. and high rpm from the
very start. I
have even gone so far as to start the eng at the end of the runway and take
off
immeadiately. Of course a short run after eng. installation to check for oil
leaks is
nessary but at all costs avoid ideling or low power settings in the air. I
try to run a new
eng. for 2-3 hrs. on the first flight.
I use non dispersant mineral oil for about the first 50 hrs. changing at 10
and 25 hr.
intervals. I use 1-2 qts. the first 10 hrs. After the eng. is "broken in"
(100 hrs.) I will
use about 1 qt every 10-15 hrs. I don't think chrome cyls. will ever be as
oil consumption
free as steel cyls. but I sure do think they last a lot longer. The main
thing about new
chrome cyls. is NOT TO BABY THEM!!
With this method I have had engs. go to 1700 hrs. with still good chrome in
the barrels and
good compression.
Hope this is of some help to you
Alex Russell
cylinders
Received: from [137.186.225.22] (helo=ms01-276.tor.istar.ca)
id 11IHsc-0003WL-00; Sat, 21 Aug 1999 16:36:47 -0400
Mime-Version: 1.0
Message-Id: <E11IHsc-0003WL-00@mail4.toronto.istar.net>
Date: Sat, 21 Aug 1999 16:36:47 -0400
Thanks for the tips, Alex ! I'm sure they'll help several builders,
when it's flying time !! :-)
---------------------------------orig.--------------------------------------
At 10:53 PM 8/20/99 EDT, you wrote:
Bill & Bob
chrome cyls. on L-0360 engs. and overhauled several engs. using re-chromed
or just honed and etched barrels. Not to be confused with "cermichrome"
cyls. I have found the best way to break in new cyls. was to run the eng.
hard, that is, high man. press. and high rpm from the very start. I have
even gone so far as to start the eng at the end of the runway and take off
leaks is nessary but at all costs avoid ideling or low power settings in the
air. I try to run a new eng. for 2-3 hrs. on the first flight.
and 25 hr. intervals. I use 1-2 qts. the first 10 hrs. After the eng. is
"broken in" (100 hrs.) I will use about 1 qt every 10-15 hrs. I don't think
chrome cyls. will ever be as oil consumption free as steel cyls. but I sure
do think they last a lot longer. The main thing about new chrome cyls. is
NOT TO BABY THEM!!
the barrels and good compression.
Alex Russell
cylinders
Received: from netcom.ca (geo-on1-10.netcom.ca [207.181.109.10])
by tor-smtp1.netcom.ca (8.8.7-s-4/8.8.7) with ESMTP id VAA16748
for <murphy-rebel@dcsol.com>; Sat, 21 Aug 1999 21:13:00 -0400 (EDT)
Message-ID: <37BF4E70.D316F358@netcom.ca>
Date: Sat, 21 Aug 1999 21:12:16 -0400
X-Mailer: Mozilla 4.04 [en] (Win95; U)
MIME-Version: 1.0
To: " (Murphy Rebel Builders List)" <murphy-rebel@dcsol.com>
References: <5734fea1.24ef6ebe@aol.com>
For those interested I found out recently that Lycoming produce a video on
how to look
after new or overhauled engines in the run in period and to obtain the
maximum life out of
them. I have a copy. It has the same message for running in mentioned by
AzAlexR@aol.com
That is don't baby the engine for a start. I can provide details if anyone
is interested
Mike Dowhan
Rebel 392R
cylinders
Received: from default (AS52-19-188.cas-kit.golden.net [209.183.131.188])
by phantom.golden.net (8.9.3/8.9.3) with SMTP id XAA02298
for <murphy-rebel@dcsol.com>; Sun, 22 Aug 1999 23:53:39 -0400 (EDT)
Message-ID: <001601beed1b$c9651f20$bc83b7d1@default>
Date: Sun, 22 Aug 1999 23:58:36 -0400
MIME-Version: 1.0
X-Priority: 3
bill here is a site to help you track down your cyl problems =
http://www.sierra.net/skyranch/blow.htm=20
peter k
sr003
D.=20
IN THE=20
THE 912=20
BEEN IN=20
BILL NEWKIRK
