Mazda 20b turbo
Al Paxhia
Mazda 20b turbo
Post by Al Paxhia » Sat Feb 18, 2012 9:40 am
Barny,
Great choice. I had thoughts of this engine but was too overwhelmed by
building the airplane to consider a auto based engine. I have owned several
rotary engines (RX-2 to RX-7) and they are almost as vibration free as a
turbine. The look of the cowl should also give you that turbine look. People
will ask is that the new "turbine Moose". Keep us posted, I may build
another airplane yet.
Al
Moose, N526AP
Sent: Sunday, November 07, 2004 7:33 AM
Subject: Re: Chevy engine mount
Mike,
Originally wanted to put the MP14 radial on my super rebel. Went over
everything with my tech counselor and decided not too. I really appreciate
what the first guys did to get flying. Being a small block chevy motor
gearhead, also looked into what you are doing. Nice, but still too much
weight. Not a big fan of Lycosaurs also. Going with a Mazda 20b turbo, 3
rotor, rotary engine.
Ordered a used motor from North Carolina for disassembly and overhaul
myself. $3000.
Going with 3mm Racing apex seals, Teflon Encased orings and viton oil
seals.
A turbo normalized system for 300 hp. Only two pounds of boost. Block is
built for a minimum of 450 hp.
Going with Tracys EC2 for ignition and fuel injection, his EM for engine
instrumentation, and his RD2B for a drive unit. The drive unit is left
handed at 2.17. It also keeps the thrustline correct.
http://www.rotaryaviation.com/
TRW 3003 throttle body. Dual fuel pumps and filters.
The motor mount is from Jerry Hey, set up for float ops, but doesn't swing
out. $1200.
Will be mounting the oil and water radiators under the engine using K&M
for
airflow. Going with a Meziere water pump.
A prop from IVO, magnum electric.
Why????
Don't have to worry about hot starts when something goes wrong and have to
restart an engine for a plane on floats.
No preheat. No shock cooling. The block is basically idiot proof. No
valves
to burn up, or cranks to trash. Accessories will be where the problems are
going to be. No vacuum pump, going electric. Engine will run on auto/av
gas.
Lots of heat in the winter. Can run the engine at 300 hp all day if I
wanted
to. Unfortunately it will have the same fuel burn rate as a Lycosaurus.
Much
smoother, less vibratation. It sounds horrible tho, like a V-6 engine.
Flying 20bt's are weighing in at 450 lbs FFW, the block weighs 255 lbs.
Barny
MGDQ 20bt Super Rebel SR103
To: Rebel List <rebel-builders@dcsol.com>
Sent: Friday, November 05, 2004 3:54 PM
Subject: Chevy engine mount
For those rare folks contemplating a Chevy for their Super Rebel or Moose
have uploaded two pictures of my engine mount under construction to the
SR/Moose-Engine section. I figure I owe it to you (and me) crazies that
would turn your backs on the ole reliable Lycosaurs to report the
following:
Chevy Rodeck aluminum block, Airflow Research heads, Lunati rotating
assembly (roller rockers and lifters), Edelbrock intake manifold, Holley
650
double pumper, PowerMaster lightweight starter, 100 amp chrome
alternator,
Sanderson headers. $15,000
Firewall Forward CAM-500 helical gear reduction unit. $12,500
IVO Prop Magnum airboat 84 inch 3-blade prop with electric pitch control
constant speed module. $2,800
Custom engine mount. $6,000
Miscellaneous custom parts. Adapter plate between Chevy flexplate and
PSRU
supplied torsion damper. $300.
Custom cowl. ???
Miscellaneous yet to be done. I.e., cooling and exhaust systems mostly.
Minus the cowl and the cooling/exhaust I've already spent $36,600.
Granted,
I went all out on the engine and bought probably the most expensive PSRU
on
the market. I imagine that you could build the engine for half what I
spent
and probably the same for the PSRU. However, there are few choices for
PSRUs that can handle the 425HP my Dyno program tells me I should get. I
think of it this way - How much would you spend for a Lycoming that can
produce 425HP? Wouldn't that be an IO-720 or something? How much would
you
spend for a rebuilt Lycoming IO-540 that can produce only 350HP (special
540
configuration)? How much would you spend for a Hartzell three blade
constant speed prop?
It's been challenging and a true "experiment". I have learned a lot. I
will have a very unique airplane. And if I get the performance the
engine
is capable of, I should get out of those small lakes pretty well. Just
engine and mount has cost me about a year and a half to put together.
And
I'm sure there are a lot more obstacles ahead. If I had it to do over
again
I would probably look more closely at companies like EPI, Inc.
(http://www.epi-eng.com/) that offer complete conversions including
mounts
and reduction units. Off the shelf LS1/LS6 conversions with the help of
someone like Brian Robertson (Chevy SeaBee) might be easier too. But I
don't regret building the engine with my own two hands and learning
everything I now know about this process now.
SR044
P.S. I have a nice set of Patriot angle head block hugger headers coated
by
Performance Coatings in Washington with their satin finish for sale.
Didn't
fit my angle plug heads from Airflow Research but should fit a standard
chevy angle plug head. One of those oops that keeps setting me back. I
still had to cut the ends off my Sanderson headers to add an extension on
the collector to miss my aluminum engine mount brackets. What next?
_____________________________________________________
This message scanned for viruses by CoreComm
Dan Stewart
Mazda 20b turbo
Post by Dan Stewart » Sat Feb 18, 2012 9:40 am
Al, you are too old!!!!
