Tailspring Support
brad
Tailspring Support
Post by brad » Sat Feb 18, 2012 9:40 am
Help...
This my sound silly but acording to MAM's instructions (page 42)
Fus 85 and Fus 87 are supposed to be bolted together with four AN3-5A bolts
bach to back with the heads of the bolts on the inside.
As near as I can figure there is no way to fit these bolts in to the FUS-87
Any Suggestions?
Brad.
bhewlett@omni-techsys.com
Tailspring Support
Post by Ken » Sat Feb 18, 2012 9:40 am
Brad
Which airplane?
brad@dcsol.com wrote:
Help...
Any Suggestions?
Brad.
brad
Tailspring Support
Ken,
Sorry,
It's a Rebel.
Brad
On 11/6/2004 9:17 AM, KLEHMAN@ALBEDO.NET wrote to REBEL-BUILDERS:
-> Received: by dcsol.com (Wildcat! SMTP Router v6.0.451.3)
-> for rebel-builders@dcsol.com; Sat, 06 Nov 2004 09:10:51 -0900
-> Received: from juliet.albedo.net ([206.51.22.2]) EHLO=juliet.albedo.net
-> by dcsol.com (Wildcat! SMTP v6.0.451.3) with SMTP
-> id 90545375; Sat, 06 Nov 2004 09:10:49 -0900
-> Received: from albedo.net (ppp214.albedo.net [206.51.22.214])
-> (authenticated bits=0)
-> by juliet.albedo.net (8.12.11/8.12.3) with ESMTP id iA6IAkpq000324
-> for <rebel-builders@dcsol.com>; Sat, 6 Nov 2004 13:10:47 -0500
-> Message-ID: <418D153D.6090109@albedo.net>
-> Date: Sat, 06 Nov 2004 13:17:33 -0500
-> From: Ken <klehman@albedo.net>
-> User-Agent: Mozilla/5.0 (Windows; U; Win98; en-US; rv:1.0.2)
Gecko/20021120 Netscape/7.01
-> X-Accept-Language: en-us, en
-> X-Orig-MIME-Version: 1.0
-> Subject: Re: Tailspring Support
-> References: <1099755987@dcsol.com>
-> X-Orig-Content-Type: text/plain; charset=us-ascii; format=flowed
-> X-Virus-Scanned: ClamAV 0.80/565/Sat Oct 30 09:31:13 2004
-> clamav-milter version 0.80j
-> on juliet.albedo.net
-> X-Virus-Status: Clean
-> X-Antivirus-Remover: Message filtered with wsAV v2.0.0 Build 001
-> Brad
-> Which airplane?
-> Ken
-> brad@dcsol.com wrote:
-> >Help...
-> >This my sound silly but acording to MAM's instructions (page 42)
-> >Fus 85 and Fus 87 are supposed to be bolted together with four AN3-5A
bolts
-> >bach to back with the heads of the bolts on the inside.
-> >As near as I can figure there is no way to fit these bolts in to the FUS-
87
-> >Any Suggestions?
-> >Thanks,
-> >Brad.
-> >bhewlett@omni-techsys.com
-> > List archives located at: https://www.dcsol.com/login?mode=HTML
Tailspring Support
Brad
OK, found the reference. I remember this has come up before so there is
something in the archives. It's hazy for me but I think some folks said
they had no problem. Some might have put the bolts on at least one side
with the nuts in the middle?? As long as you can still get the vertical
tailspring bolt in I don't see why it would matter which way the bolts
go in...
Ken,
Sorry,
It's a Rebel.
Brad
-> >Help...
bolts
87
-> >Thanks,
-> >Brad.
brad
Tailspring Support
Thanks Ken.
Yes they will fit if you put the nuts on the inside for one of the sides.
I was concerned about doing that because MAM is very specific about the heads
of the bolts going to the inside.
Just a note, I do search the archives before I tackle each stage and it's
amazing the knowledge and help thats on this list.
Brad (R195)
On 11/6/2004 2:55 PM, KLEHMAN@ALBEDO.NET wrote to REBEL-BUILDERS:
-> for rebel-builders@dcsol.com; Sat, 06 Nov 2004 14:48:50 -0900
-> id 110823875; Sat, 06 Nov 2004 14:48:48 -0900
-> Received: from albedo.net (ppp168.albedo.net [206.51.22.168])
-> by juliet.albedo.net (8.12.11/8.12.3) with ESMTP id iA6NmiEF022477
-> for <rebel-builders@dcsol.com>; Sat, 6 Nov 2004 18:48:45 -0500
-> Message-ID: <418D6473.40703@albedo.net>
-> Date: Sat, 06 Nov 2004 18:55:31 -0500
-> References: <1099769823@dcsol.com>
-> Brad
-> OK, found the reference. I remember this has come up before so there is
-> something in the archives. It's hazy for me but I think some folks said
-> they had no problem. Some might have put the bolts on at least one side
-> with the nuts in the middle?? As long as you can still get the vertical
-> tailspring bolt in I don't see why it would matter which way the bolts
-> go in...
-> Ken
-> >Ken,
-> >Sorry,
-> >It's a Rebel.
-> >Brad
-> >> brad@dcsol.com wrote:
-> >-> >Help...
-> >-> >This my sound silly but acording to MAM's instructions (page 42)
-> >-> >Fus 85 and Fus 87 are supposed to be bolted together with four AN3-5A
-> >bolts
-> >-> >bach to back with the heads of the bolts on the inside.
-> >-> >As near as I can figure there is no way to fit these bolts in to the
FUS-
-> >87
-> >-> >Any Suggestions?
-> >-> >Thanks,
-> >-> >Brad.
-> >-> >bhewlett@omni-techsys.com
rognal
Tailspring Support
Post by rognal » Sat Feb 18, 2012 9:40 am
Brad,
I asked Brian at MAM Tech about this a couple years ago. He told me it was OK
to reverse the bolts. Why they don't take a couple of minutes to edit the
instruction so new manuals will be correct is beyond me. If you read ahead to
the fuselage building chapter you will see a drawing of the engine mount
brackets bolted together with the bolt heads outside. The parts are similiar.
Roger Hoffman #687R
Eugene, OR USA!
