Chevy engine mount
Posted: Sat Feb 18, 2012 12:40 pm
For those rare folks contemplating a Chevy for their Super Rebel or Moose I
have uploaded two pictures of my engine mount under construction to the
SR/Moose-Engine section. I figure I owe it to you (and me) crazies that
would turn your backs on the ole reliable Lycosaurs to report the following:
Chevy Rodeck aluminum block, Airflow Research heads, Lunati rotating
assembly (roller rockers and lifters), Edelbrock intake manifold, Holley 650
double pumper, PowerMaster lightweight starter, 100 amp chrome alternator,
Sanderson headers. $15,000
Firewall Forward CAM-500 helical gear reduction unit. $12,500
IVO Prop Magnum airboat 84 inch 3-blade prop with electric pitch control and
constant speed module. $2,800
Custom engine mount. $6,000
Miscellaneous custom parts. Adapter plate between Chevy flexplate and PSRU
supplied torsion damper. $300.
Custom cowl. ???
Miscellaneous yet to be done. I.e., cooling and exhaust systems mostly.
Minus the cowl and the cooling/exhaust I've already spent $36,600. Granted,
I went all out on the engine and bought probably the most expensive PSRU on
the market. I imagine that you could build the engine for half what I spent
and probably the same for the PSRU. However, there are few choices for
PSRUs that can handle the 425HP my Dyno program tells me I should get. I
think of it this way - How much would you spend for a Lycoming that can
produce 425HP? Wouldn't that be an IO-720 or something? How much would you
spend for a rebuilt Lycoming IO-540 that can produce only 350HP (special 540
configuration)? How much would you spend for a Hartzell three blade
constant speed prop?
It's been challenging and a true "experiment". I have learned a lot. I
will have a very unique airplane. And if I get the performance the engine
is capable of, I should get out of those small lakes pretty well. Just the
engine and mount has cost me about a year and a half to put together. And
I'm sure there are a lot more obstacles ahead. If I had it to do over again
I would probably look more closely at companies like EPI, Inc.
(http://www.epi-eng.com/) that offer complete conversions including mounts
and reduction units. Off the shelf LS1/LS6 conversions with the help of
someone like Brian Robertson (Chevy SeaBee) might be easier too. But I
don't regret building the engine with my own two hands and learning
everything I now know about this process now.
SR044
P.S. I have a nice set of Patriot angle head block hugger headers coated by
Performance Coatings in Washington with their satin finish for sale. Didn't
fit my angle plug heads from Airflow Research but should fit a standard
chevy angle plug head. One of those oops that keeps setting me back. I
still had to cut the ends off my Sanderson headers to add an extension on
the collector to miss my aluminum engine mount brackets. What next?
Custom cowl. ???
SR044
