Corrosion proofing.
Posted: Fri Feb 17, 2012 5:26 pm
Received: from ne.com.au (tc1-36.ne.com.au [203.13.72.228]) by
redback.ne.com.au
(8.8.7/8.7.3) with ESMTP id WAA01836 for <murphy-rebel@dcsol.com>; Fri, 20
Aug 1999 22:34:15
+1000
Message-ID: <37BD4BC4.E04A068@ne.com.au>
Date: Fri, 20 Aug 1999 22:36:20 +1000
MIME-Version: 1.0
To: "(Murphy Rebel Builders List)" <murphy-rebel@dcsol.com>
Subject: Corrosion proofing.
G'day From Australia
I have a few questions regarding corrosion proofing that I would
appreciate some help on, and they are;
1 Just what must be done to clean the parts that form part of the
internal structure before chromating?
2. Can the zinc chromate be brushed on or must it be sprayed?
3. How thick should the coat be?
4. Can the parts be assembled wet or must the chromate be dry?
5. Is there any value, or in fact any need, to chromate the entire
internal structure?
6. When I finish the factory supplied chromate, could I use other
brands? Compatibility?
7. Should the fuselage be fully chromated internally? And if so at what
stage?
8. Should the skins be chromated externally, where the rivets will go,
before assembly, so that there will be chromate under the rivet?
Thanks and regards
Ian Donaldson
redback.ne.com.au
Aug 1999 22:34:15
+1000
MIME-Version: 1.0
internal structure?
stage?
Thanks and regards
Ian Donaldson
