Oshkosh thoughts
Oshkosh thoughts
Post by Mike Davis » Fri Feb 17, 2012 5:26 pm
Received: from d12relay01.de.ibm.com (d12relay01.de.ibm.com [9.165.215.22])
by d12lmsgate-3.emea.ibm.com (1.0.0) with ESMTP id IAA28848
for <murphy-rebel@dcsol.com>; Fri, 20 Aug 1999 08:31:17 +0200
Received: from d12mta05.de.ibm.com (d12mta05_cs0 [9.165.222.239])
by d12relay01.de.ibm.com (8.8.7m1/NCO v2.04) with SMTP id IAA150490
for <murphy-rebel%dcsol.com@Internet.ae.ibm.com>; Fri, 20 Aug 1999 08:31:05
+0200
Received: by d12mta05.de.ibm.com(Lotus SMTP MTA Internal build v4.6.2
(651.2 6-10-1998))
id C12567D3.0023CB95 ; Fri, 20 Aug 1999 08:30:58 +0200
X-Lotus-FromDomain: IBMDE
Message-ID: <C12567D3.0022921F.00@d12mta05.de.ibm.com>
Date: Fri, 20 Aug 1999 08:17:31 +0200
Subject: Oshkosh thoughts
Mime-Version: 1.0
Content-type: text/plain; charset=us-ascii
Content-Disposition: inline
Hi,
I have noticed two interesting little mods in this year's Murphy
demonstrators:
brake cylinder mounting:
MAM followed Dave Bangle's advice to mount the lower part of the brake
cylinders to the floor (with two angle brackets per cylinder). This should
improve wear and handling characteristics.
Brake lines:
MAM changed from the plastic lines to real airplane hoses, I guess because
of higher pressure limits. Did anybody of the flying Rebels experience
problems with the plastic lines?
Another thing I've seen in the vendor section are reasonable priced
(65-75$) pneumatic tailwheels (so far only Scott had very expensive 8"
wheels) from Andair, which could be exchanged with the standard solid, hard
riding Rebel tailwheel. The only thing which bothers me is the reduced max
load 200-300 #, instead of 460 # of the solid wheel. Would you think this
is still enough? How much weight goes to the tail wheel at gross? Darryl
Murphy was not able to tell.
Stefan Pappe, Heidelberg, Germany , 156R
Oshkosh thoughts
Received: from albedo.net (ppp116.albedo.net [206.51.22.135])
by juliet.albedo.net (8.9.0/8.9.0) with ESMTP id JAA04654
for <murphy-rebel@dcsol.com>; Fri, 20 Aug 1999 09:33:31 -0400
Message-ID: <37BD53DF.9A4B0D73@albedo.net>
Date: Fri, 20 Aug 1999 09:10:55 -0400
X-Mailer: Mozilla 4.08 [en] (Win95; I)
MIME-Version: 1.0
To: " (Murphy Rebel Builders List)" <murphy-rebel@dcsol.com>
Subject: Re: Oshkosh thoughts
References: <C12567D3.0022921F.00@d12mta05.de.ibm.com>
PAPPE@de.ibm.com wrote:
Hi,
demonstrators:
Also nifty mechanical brake pedal linkage from the right seat to the master
cylinders on the Elite.
Oshkosh thoughts
Received: from [154.11.83.89] (helo=ip89.mississauga2.dialup.canada.psi.net)
by mail4.toronto.istar.net with smtp (Exim 1.92 #2)
for murphy-rebel@dcsol.com
id 11Hulj-0006uR-00; Fri, 20 Aug 1999 15:56:07 -0400
Mime-Version: 1.0
To: <murphy-rebel@dcsol.com> (Murphy Rebel Builders List)
Message-Id: <E11Hulj-0006uR-00@mail4.toronto.istar.net>
Date: Fri, 20 Aug 1999 15:56:07 -0400
Plastic brake lines: have used them for 9 years on one Rebel, and
6 years on the other. No problems ! They are also used on the amphib
floats for gear retraction - again: No problems !!
The Andair pneumatic wheels sound interesting - will they directly
replace the solid wheel, with no mods. ?? Why the reduced load limit ??
Is it the structure of the wheel, or just the tire load limits ??
I would be surprised if you ever get 300 LB. on the tail, even at gross.
I believe usual loads are more in the 100 LB. range ... vertically -
side loads are another issue, and one that needs attention !
-----------------------------orig.-----------------------------------------
At 08:17 AM 8/20/99 +0200, you wrote:
Hi,
demonstrators:
Brake lines:
Oshkosh thoughts
Received: from enaila.nidlink.com (root@enaila.nidlink.com [216.18.128.8])
by lanfear.nidlink.com (8.9.0/8.9.0) with ESMTP id GAA02621
for <murphy-rebel@dcsol.com>; Sat, 21 Aug 1999 06:40:07 -0700 (PDT)
Received: from nidlink.com (pm5-10.nidlink.com [216.18.141.17])
by enaila.nidlink.com (8.9.0/8.9.0) with ESMTP id GAA08649
for <murphy-rebel@dcsol.com>; Sat, 21 Aug 1999 06:40:05 -0700 (PDT)
Message-ID: <37BEAE77.F2B4AA4@nidlink.com>
Date: Sat, 21 Aug 1999 06:49:43 -0700
X-Mailer: Mozilla 4.5 [en] (Win95; I)
X-Accept-Language: en
MIME-Version: 1.0
Content-Type: text/plain; charset=x-user-defined
Actually, the credit goes to Keith Kinden. I didn't follow his advise
until I looped mine. Then it seemed more important to listen. :)
Dave Bangle http://www.subielyc.com/
