Moose - M14 carburator jets
Posted: Sat Feb 18, 2012 9:39 am
Below are two emails from a discussion on another list referencing the
accelerator jets on the M14 carburetor.
I ended up ordering the .9mm jet and will try that. I know Ted liked the
results of doing the mod that completely plugged the jet, figured I would
try this first and go from there. I wrote emails to the local M14 importers
to see if they had these jets and got no reply. Rob Kent from
www.wlacrussianeng.co.uk <http://www.wlacrussianeng.co.uk/> was very
helpful and called the same day I placed the internet order to discuss
shipping ( I suspect his phone call from England to the US cost more than
the shipping).
Anyway, good guys and they have a lot of the smaller parts for the M14 in
stock.
Scott
Moose 174
"Richard Goode" <richard.goode@russianaeros.com>
Subject:
Accelerator Jet
<http://www.matronics.com/searching/getm ... 83?KEYS=ri
chard_goode?LISTNAME=Yak?HITNUMBER=17?SERIAL=16514612918?SHOWBUTTONS=NO>
Date:
Sep 27, 2004
Accelerator Jet
I have seen with interest correspondence on this.
In my humble opinion blocking the jet is a rather crude solution.
The AK14 carburetor is very sophisticated, and unfortunately, few people
understand
either its workings, or how to set it up.
The accelerator jet has the specific purpose of momentarily increasing the
richness
of the mixture to avoid hesitation on opening the throttle. Clearly too
much fuel at this stage can also cause a hesitation through a "rich cut."
The manufacturers get round this by having six different jets, which are
interchangeable
(ranging from 0.9mm to 1.4mm).
I can see that an engine with a very large jet and therefore noticeable rich
hesitation
will improve by having the jet blanked off completely, but generally
it has got to be a far better solution to install the correct jet!
A well set up M14P will generally run like a sewing machine - sadly very few
are!
Richard Goode
Richard Goode Aerobatics
Rhodds Farm
Lyonshall
Herefordshire
HR5 3LW
United Kingdom
Tel: +44 (0) 1544 340120
Fax: +44 (0) 1544 340129
www.russianaeros.com
Match:
#1
Message:
#16280
"Rob Kent" <spares@russianaeros.com>
Subject:
carb jets
<http://www.matronics.com/searching/getm ... 68?KEYS=ca
rb_jets?LISTNAME=Yak?HITNUMBER=1?SERIAL=16501012580?SHOWBUTTONS=NO>
Date:
Sep 29, 2004
The carburetor uses a number of different jets. In his email Richard
mentions the acceleration pump fuel jet. These jets are the same as the
suction jets. The only difference between the two is the diameter of the
hole in the jet.
The suction jets range in interchangeable sizes from 1.3mm to 2.0mm
inclusive. Increasing the jet diameter will lean out the mixture. Decreasing
the jet diameter enriches the mixture and helps keep the engine cool at high
power settings. A change in jet diameter of 0.1mm changes the specific fuel
consumption at take-off rating for 10 to 15 grams per horse power per hour.
It is normal practice, after changing this jet to adjust the engine in
cruise
rating II via the metering needle adjustment screw.
The acceleration pump fuel jets range in interchangeable sizes from 0.9mm to
1.4mm inclusive. When increasing the acceleration jet diameter, the
acceleration pump delivery increases and vice versa.
These jets are available from stock as a set ranging from 0.9mm to 1.9mm
inclusive (one of each size per set) or as individual sizes (2.0mm not
available). More information can be obtained by contacting me by phone, fax
or email or, alternatively by visiting our website.
Regards
Rob Kent
Stores Manager
WLAC - Russian Engineering
Tel:- +44 1628 829165
Fax:- +44 1628 828961
the shipping).
stock.
Scott
Moose 174
Subject:
Accelerator Jet
Date:
Sep 27, 2004
Accelerator Jet
understand
richness
interchangeable
hesitation
are!
Richard Goode
Rhodds Farm
Lyonshall
Herefordshire
HR5 3LW
United Kingdom
Match:
#1
Message:
#16280
Subject:
carb jets
Date:
Sep 29, 2004
hole in the jet.
cruise
Regards
Rob Kent
Stores Manager
