Page 1 of 2
Rivet head bur
Posted: Sat Feb 18, 2012 12:35 pm
by Scott Aldrich
I know I am not the only one that has little burs on a lot of the Avex rivet
heads after pulling them with the cheapo air puller. It is caused by the
pulling head being slightly to large for the rivet. They are time consuming
to remove.
The "fix" from Steve: Take the smallest rivet pulling head (steal one off
your even cheaper WalMart hand puller, it should fit) and drill it out to an
exact fit for the RV14 rivet and you won't get the bur anymore.
Scott
Moose 174
Rivet head bur
by David Ricker
Scott
We noticed this too and have been using the smallest nose that the mandrel will
fit through and having good luck. The only down side is the gun is reluctant to
give up the mandrel every time.
to remove.
Scott
Moose 174
David A. Ricker
Fall River, Nova Scotia
Canada
Rivet head bur
by WALTER KLATT
And hopefully you guys don't have any of the bad batch of 1410 rivets that MAM sent out many years ago with the kits. These were also breaking off too high and leaving burrs to stick above the heads. They were supposed to have been all recalled.
Date: Friday, October 29, 2004 2:43 pm
Subject: Re: Rivet head bur
Scott
mandrel will
is reluctant to
the Avex rivet
caused by the
time consuming
to remove.
(steal one off
it out to an
Scott
Moose 174
David A. Ricker
Canada
Rivet head bur
The had gold dichromated stems and came from Rivets Unlimited!
Sent: Friday, October 29, 2004 6:49 PM
been all recalled.
Scott
mandrel will
is reluctant to
the Avex rivet
caused by the
time consuming
to remove.
(steal one off
it out to an
Scott
Moose 174
David A. Ricker
Canada
Rivet head bur
by Scott Aldrich
We had a few that the stem broke off high on the bottom wing skin, not a lot
though so I don't think it was any of the recalled rivets. Ground those all
off with the dremel also.
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com] On Behalf Of WALTER
KLATT
Sent: Friday, October 29, 2004 4:49 PM
been all recalled.
Scott
mandrel will
is reluctant to
the Avex rivet
caused by the
time consuming
to remove.
(steal one off
it out to an
Scott
Moose 174
David A. Ricker
Canada
Rivet head bur
by David Ricker
Yeah, but MAM only replaced HALF of them & told us to use the rest in
inconspicuous places......
been all recalled.
Scott
mandrel will
is reluctant to
the Avex rivet caused by the time consuming (steal one off it out to an --
David A. Ricker
Canada
David A. Ricker
Canada
Rivet head bur
And that's a pretty hard thing to do when 80%++ are on the outside isn't it
Sent: Friday, October 29, 2004 7:35 PM
that
too
have
been all recalled.
David A. Ricker
Canada
Rivet head bur
by David Ricker
Yeh, you didn't see my invisible frowny face icon did you!
that
too
have
been all recalled. -----------------------------------------------------
David A. Ricker
Canada
David A. Ricker
Canada
Rivet head bur
by Drew Dalgleish
At 06:43 PM 10/29/2004 -0300, you wrote:
Scott
will
reluctant to
Ya just gotta learn to give a flip of the wrist so the mandrel drops out
the back ;)
Rivet head bur
by David Ricker
Yeah except it hangs in the teeth of the pulling jaws. I haven't managed to
adjust it so it will let it go, I don't think there is enough clearance or
perhaps alignment in the tool??
Scott
will
reluctant to
the back ;)
David A. Ricker
Canada
Rivet head bur
Sometimes if the tip is a real close fit this happens...but usually if you
take the nose off, unlock the lock nut and move the tip assembly forward a
thread or so...then relock. This lets the tips assembly get pushed a little
further forward when the gun retracts and opens the puller jaws a bit more.
Sent: Friday, October 29, 2004 10:56 PM
Scott
mandrel
will
reluctant to
the back ;)
David A. Ricker
Canada
Rivet head bur
by David Ricker
Yeah, played with it couple of times but I am still not satisfied, maybe when I
have time for more patience ;o)
mandrel
will reluctant to Ya just gotta learn to give a flip of the wrist so the mandrel drops out
the back ;)
David A. Ricker
Canada
David A. Ricker
Canada
Rivet head bur
by Rick Harper
I sure as hell got a few of 'em "down here" !!!
Rick & Wendy Harper
541R
Sent: Saturday, October 30, 2004 10:35 AM
rivets that
off too
to have
been all recalled.
Scott
mandrel will
is reluctant to
drill
it out to an
anymore.
David A. Ricker
Canada
David A. Ricker
Canada
Rivet head bur
by Ken
Even easier might be to try putting a few drops of oil into the air line
first. If I forget to do this every thousand rivets or so my puller gets
stiff and doesn't retract (go forward?) all the way...
mandrel
will
reluctant to
the back ;)
Rivet head bur
by Jean Poirier
To machine the head nose, do you just use a drill? A 132' or a 118'....
We may do it with the 3/16'' rivet to.... About the "bad" batch of
rivet... with my kit I have receive many type of rivets.... 1/8 and 3/16.
When I make a "bad hole" I had to go for a 3/16 which is big... Las t yeay
at the Sun'Fun, I have buy some 5/32"(that I have not use yet... may be my
"technic" is better) but they have the "gold" mandrel. Could I use them any
way ? Is there oversize compare to a 1/8' will compensate for the ?
quality..
Jean
Rebel 747R
Sent: Monday, November 01, 2004 9:08 AM
you
little
more.
managed
or
mandrel
out
