Moose - cracking under outboard aileron hinge bracket
Posted: Sat Feb 18, 2012 12:31 pm
I just posted pictures in the archives (S/M wings) showing cracks forming
under the left outboard aileron hinge bracket. It is in the left wingtip rib
flange and rear spar of an M14 powered Moose. The aircraft has about 100
hours with a two blade prop.
These are similar to the cracking that Murphy had in the demonstrator on the
outboard stab and elevator hinge area. I can not remember if they mentioned
the wing tips at that time or not. I sent this info to Brian already.
I only found cracks on the left tip not on the right. The right may be less
prone to the cracking due to rib flange being out instead of in.
I am going to add angle reinforcement similar to what we did to the tail.
Scott
Moose #174
Scott
Moose #174
