Firewall fix for floats
Peter, Juliet, & Wanaao P
Post by Peter, Juliet, & Wanaao P » Sat Feb 18, 2012 9:31 am
Wayne:
How does your fix compare to what MAM recommends for the firewall fix
on a Rebel?
I just put mine on floats and want to do the fix next month when it
comes off floats.
Yours makes sense. Lots of room compared to the 2" channel aluminum.
Peter
Yellowknife, NT
Post by Wayne G. O'Shea » Sat Feb 18, 2012 9:31 am
Peter...my "fix" has been utilized since 1996! Haven't had a firewall buckle
with them in place since. Even on Howard's total wreck they held the
firewall
straight and I can reuse it!!(and his fuselage is now almost 2" longer and 3
" shorter than it should be!!).
MAM's suggested .020 channels are toooo light! Go to .032 and they will
do something. My plates are .063 and tie a larger section together with the
witches hats for ultimate load distribution. If you look at our website
pictures you can
build your own set or order a set from me...your choice and if you can
source a
small quantity of .063 to do them yourself go ahead....won't hurt my
feelings.
The other thing that you absolutely have to do is to take the existing
approx. 1" rivet pitch up the forward door post/carrythru and drill another
hole/rivet between each rivet and staggered about 3/16" forward of the
existing row. Where they get close together on the top 4 or 5 up by the
forward wing attach these are too close to drill another in between..so
drill these right out to 3/16 and replace with RV1613 Rivets. If you don't
do this then a hard landing on floats (or worse yet skis!) will shear the
rivets out of the entire door post from top to
bottom like a shear cutting .016 aluminum. The double row and larger rivets
at the top stops this from happening...also proven by Howard's wreck as
everything else let go except these door posts... to the point his door
posts are
now a V shape. If it hadn't been double riveted we would still be looking
for his engine/propellor and nose section in 90 feet of water!!
Murphy's tech boys back in '96 wouldn't listen to me and said it wasn't
necessary to reinforce these door posts with the extra rivets...of course
until they FU$#($'d up the factory Elite on Amphibs and Les messed up his
Rebel amphib, at Oshkosh in
front of the "world" in 1998, and what you see as their float fix bulletin
was the
result (being the band-aid gusset at the top of the door post and channels
on the firewall) The Band-Aid gusset can be done on new builds but is pretty
hard to do on something flying unless you happen to be changing the
windshield. The staggered row of rivets and 4 or 5 RV1613's at the top,
that I do, has been proven by the test of time and total aircaft
destruction..... so I know it works (and well)!
From: "Peter, Juliet, & Wanaao Piascik" <northofsixty@mac.com>
Sent: Tuesday, September 21, 2004 11:40 AM
Subject: Firewall fix for floats
Wayne:
on a Rebel?
comes off floats.
Peter
Yellowknife, NT
Thanks Wayne for the info.
I work for First Air and can easily get some .063.
You have to fly up here some year. Just a little way out of the way on
route to Nimpo Lake.
Thanks again,
Peter
PS I do have to replace my windshield, hit a boat wake. Stitched for
now until off floats and in a hanger. Do you still recommend the second
row of rivets only?
buckle
firewall
and 3
with the
pictures you can
source a
feelings.
another
don't
rivets
posts are
looking
course
his
bulletin
was the
channels
pretty
top,
Wayne:
on a Rebel?
comes off floats.
Peter
Yellowknife, NT
Post by Walter Klatt » Sat Feb 18, 2012 9:31 am
Peter, don't you guys have some kind of midnight fly-in up there
around June 21. One of the guys here is trying to talk me into
going there next year.
Sent: Tuesday, September 21, 2004 7:45 PM
Subject: Re: Firewall fix for floats
out of the way on
Thanks again,
Peter
wake. Stitched for
row of rivets only?
buckle
wreck they held the
firewall
and 3
.032 and they will
section together
with the
look at our website
pictures you can
source a
feelings.
take the existing
another
don't
skis!) will shear
rivets
the point his door
posts are
would still be
looking
of water!!
and said it wasn't
extra rivets...of
course
and Les messed up
his
their float fix
bulletin
was the
door post and
channels
new builds but is
pretty
be changing the
RV1613's at the
top,
total aircaft
Wayne:
on a Rebel?
next month when it
comes off floats.
channel aluminum.
Peter
Yellowknife, NT
Second row of rivets with tops at wing attach area 3/16 seems to be plenty
(as confirmed by Howard's latest mess). Also hard to put the MAM "Band-Aid"
gusset on after the fact.... easy to do internally (ie under the Fus-9's)
when building new, but a bit tougher when things are already all together.
Sent: Tuesday, September 21, 2004 10:45 PM
Thanks again,
Peter
row of rivets only?
buckle
firewall
and 3
with the
pictures you can
source a
feelings.
another
don't
rivets
posts are
looking
course
his
bulletin
was the
channels
pretty
top,
Wayne:
on a Rebel?
comes off floats.
Peter
Yellowknife, NT
N.Smith
Post by N.Smith » Sat Feb 18, 2012 9:31 am
Hi Wayne / All
Sorry to drag this topic up again after a few days, but with my Elite, any
thoughts about using RV16xx's all the way up the forward door posts in the
standard holes (or even a suitable cherrymax or similar) rather than the
double hole spacing and 1410's at the bottom you recommend ?
Nigel
PS Got your brother Murray out for a beer a few weeks ago :-)
Sent: 22 September 2004 01:34
firewall
pictures you can
source a
feelings.
posts are
was the
Wayne:
on a Rebel?
comes off floats.
Peter
Yellowknife, NT
Joel Jacobs
Post by Joel Jacobs » Sat Feb 18, 2012 9:34 am
Sent: Tuesday, September 21, 2004 8:34 PM
another
Hi,
I'm getting ready to install the fus-9s now, I haven't drilled them yet and
only have two holes drilled in the fus-11s and one in the upper corner wraps
along the door post.
Just to be clear - how much of the door post gets the double row? I know
the fus-9s do but do they continue down the corner wrap section? How about
the fus-11s? Door hinge area?
As a retrofit you would have one row down the center and offset the other
row 3/16. With new construction would you recommend just putting the rows
1/3 and 2/3 across the post?
Thanks much!
Joel Jacobs
Rebel 416R
Post by Wayne G. O'Shea » Sat Feb 18, 2012 9:34 am
I double rivet top to bottom Joel...but the important thing is the top and
fus-9. Also keep in mind this was posted for a retrofit upgrade I was
advising to someone on their flying aircraft. Also with MAM following suit
with a reinforcement "float fix" gusset, two years after my "fix", you can
probably get away with just the gusset across the top....but even then I
would add the double rivets in the upper post section. As for how you pitch
it.....depends on how you finish off your window frame for sealing.
Also..I install the door hinge to the inside face of the carrythru tube, not
on the outside as per the manual. Choice is yours..both have pros and cons.
Sent: Monday, October 18, 2004 4:44 PM
another
don't
Hi,
wraps
know
about
other
Thanks much!
Joel Jacobs
Rebel 416R
Post by Ken » Sat Feb 18, 2012 9:34 am
Hi Joel
FWIW I doubled the rivets all the way down the door post. At the top I
used 1/8 structural Q rivets to keep within the recommended 4d spacing
(instead of 3/16 avex). Yes I would have staggered them if I'd known at
the time but not sure there is room to stagger them in the door hinge.
Actually we also replaced the original door hinge material with a wider
hinge but I still don't think it was wide enough to stagger the rivets.
I believe I have heard of a couple of cases of the single row of rivets
ripping out along the entire door post during a violent ground loop...
another
Hi,
Thanks much!
Joel Jacobs
Rebel 416R
Joel Jacobs
Thanks Ken, I'll stagger them the whole way down. Isn't the 4d spacing
center to center? 4d for the 3/16 rivets would be .75" and I think that's
the spacing on those...
Joel
Sent: Monday, October 18, 2004 6:38 PM
Hi Joel
another
don't
Hi,
wraps
know
about
other
rows
Thanks much!
Joel Jacobs
Rebel 416R
Yes but I guess I didn't have .75 or was uncomfortable about minimum
spacing or something there when I redid it. This was a refit mod for me.
Joel
Joel Jacobs
I measured after I got home and they're slightly less than 3/4 OC. I
guess there are some advantages to taking 10 years to build my Rebel -
I let everyone else do the trailblazing and do all the mods as I go;>)
Funny thing though - just last month I spot drilled the 6 holes for my
spring gear attachments and a week later there was an update on MAMs
site moving them inboard 1/4" - go figure...
Joel
Joel
