Received: from BILNEWKIRK@aol.com
by imo12.mx.aol.com (IMOv20.21) id bHFCa19658 (4230)
for <murphy-rebel@dcsol.com>; Mon, 19 Jul 1999 15:50:25 -0400 (EDT)
Message-ID: <8d80b448.24c4db82@aol.com>
Date: Mon, 19 Jul 1999 15:50:26 EDT
Subject: LYCOMING 0-290 BLOW-BY
MIME-Version: 1.0
X-Mailer: AOL 3.0 for Windows 95 sub 76
I HAVE 5 FLIGHTS ON MY REBEL WITH AN O-290 THAT WAS PICKLED FOR 18 YEARS.
IT
HAS GOOD POWER AND COMPRESSION, BUT IT HAS A TREMENDOUS AMOUNT OF OIL COMING
OUT THE BREATHER TUBE - MORE THAN 2 QUARTS IN A ONE-HALF HOUR FLIGHT.
HELP!!!
BILL NEWKIRK
Received: from the-benson-s
(216-164-242-203.s457.tnt10.lnh.md.dialup.rcn.com
[216.164.242.203])
by smtp1.erols.com (8.8.8/8.8.5) with SMTP id QAA20137
for <murphy-rebel@dcsol.com>; Mon, 19 Jul 1999 16:48:42 -0400 (EDT)
Message-ID: <002201bed227$c1e943c0$cbf2a4d8@the-benson-s>
Subject: Re: LYCOMING 0-290 BLOW-BY
Date: Mon, 19 Jul 1999 16:46:18 -0400
MIME-Version: 1.0
charset="iso-8859-1"
X-Priority: 3
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook Express 4.72.3155.0
X-MimeOLE: Produced By Microsoft MimeOLE V4.72.3155.0
Bill; the latest issue, July '99, of "Light Plane Maintenance" has a four
page article on Breather Tubes. You need to read that article before you do
anything drastic, such as a top overhaul!
To: murphy-rebel@dcsol.com <murphy-rebel@dcsol.com>
Date: Monday, July 19, 1999 3:52 PM
[216.164.242.203])
MIME-Version: 1.0
X-Priority: 3
ITI HAVE 5 FLIGHTS ON MY REBEL WITH AN O-290 THAT WAS PICKLED FOR 18 YEARS.
COMINGHAS GOOD POWER AND COMPRESSION, BUT IT HAS A TREMENDOUS AMOUNT OF OIL
HELP!!!OUT THE BREATHER TUBE - MORE THAN 2 QUARTS IN A ONE-HALF HOUR FLIGHT.
.BILL NEWKIRK
Received: from [137.186.225.8] (helo=ms01-262.tor.istar.ca)
by mail4.toronto.istar.net with smtp (Exim 1.92 #2)
for murphy-rebel@dcsol.com
id 116Qu7-00035a-00; Mon, 19 Jul 1999 23:49:19 -0400
Mime-Version: 1.0
To: <murphy-rebel@dcsol.com> (Murphy Rebel Builders List)
Message-Id: <E116Qu7-00035a-00@mail4.toronto.istar.net>
Date: Mon, 19 Jul 1999 23:49:19 -0400
One thought -
I hope you're not filling it right up !!! Lycomings will blow the
first quart out almost immediately !!! If it holds 8 quarts, never put
in more than 7 - it'll be gone before you go once around the patch !!!
A compression test will tell you if the rings are worn, or if it's
valves ....
------------------------------orig.-----------------------------------------
Mime-Version: 1.0
One thought -
valves ....
BILL NEWKIRK
