Moose elevator update
Post by Mike Davis » Sat Feb 18, 2012 9:23 am
Just in case anybody besides me is currently working on their Moose tail
feathers... MAM just posted an update to the elevator chapter... seems in
addition to the new EL-32 (tube over the trim tab push rod) they are also
beefing up the trim tab control horns. New parts are ELE-1001 & ELE-1002.
Reed Britt Civ OO-ALC/MAD
Post by Reed Britt Civ OO-ALC/MAD » Sat Feb 18, 2012 9:23 am
Mike - Have you seen the new horn pieces? If so - What is the difference
between the ELE-1001/2 and the old EL-36R/L? Is it heavier gauge, longer
bearing area or what? Bottom line for me - Is it worth replacing?
Britt 194SR
From: mike.davis@dcsol.com [mailto:mike.davis@dcsol.com]
Sent: Thursday, August 19, 2004 4:36 PM
Subject: Moose elevator update
Ted Waltman
Post by Ted Waltman » Sat Feb 18, 2012 9:26 am
The new horn pieces are about 6" long, versus perhaps 2" for the old
ones. MAM reports that some folks notices stress cracks in the
underlying elevator skin developing after about 100 hrs using the old
ones.
Reed Britt Civ OO-ALC/MADE
Sent: Monday, August 23, 2004 6:47 AM
Subject: RE: Moose elevator update
difference between the ELE-1001/2 and the old EL-36R/L? Is it heavier
gauge, longer bearing area or what? Bottom line for me - Is it worth
replacing?
Britt 194SR
in
also
ELE-1002.
Post by Mike Davis » Sat Feb 18, 2012 9:26 am
I haven't seen them yet, but the manual change indicates that they are
attached to the elevator with 14 rivets, 7 per side... vice the current 3 (I
think) per side. So this would make the mounting surface much longer,
distributing the twisting force over much more of the tab. I sent an e-mail
to MAM asking them to send me the new pieces, but haven't heard back yet.
From: "Reed Britt Civ OO-ALC/MADE" <Britt.REED@HILL.af.mil>
Sent: Monday, August 23, 2004 4:46 AM
Britt 194SR
