Sent: Thursday, August 12, 2004 9:17 PM
Subject: Re: Wayne's boring adventure! / Howard destroys "Pocket Change"
bobhi wayne where is the plane now at your place or his ? thanks
missedfisher
Sent: Thursday, August 12, 2004 7:07 PM
Subject: Wayne's boring adventure! / Howard destroys "Pocket Change"
I was actually singing Harry Chapin's 30,000lb's of Banana's as we came
screaming down the hill......for those that know the song! Sorry I
afterbefore!!you...you must have known I was coming to town and ran away the dayfloor!Had time to go thru all the pictures from your's and Walter's trip North
though and all looked great except that puddle of Dextron III on yourThe tip was great.... even though we did get the news on the Friday
talkvisiting with Walter that Howard rode off "Pocket Change"..his (our)
beautiful Rebel on Amphibs in Penetanguishene Harbour. I have yet to
ittohim, but the stomach turner is in the hanger and my son helped him get
damagehome (via wing remove and trailers). Apparently felt some vibration and
panic landed at about 125MPH into 3 foot swells. Amazing home much
apartwater can do at that speed. Floats are a right off..buckled and torn
prebuilts.and would take more labour to repair than the cost of a set of
bowl.Fuselage is totally destoyed from the rear float attach to the nose
wouldNot even sure how the engine stayed on.
The one thing I do know is my double row of rivets up the door post is a
great fix and not one of them sheared. If they had of let go and had the
firewall not had my reinforcing plates on it the outcome might have been
much worse and I suspect the engine would have made it off and they
atithave cartwheeled the airplane. (although I am amazed they didn't flip asthingwas and Howard and his daughter exited unscathed) Unfortunately everyelse sheared or ripped including bending the door post carrythru tubes
transitionaboutexactly where the FUS-11's meet the top wrap and FUS-9's. Cabin in now2 " shorter than the door height. Outer cabin floor to tailcone
6"cablessheared EVERY rivet and the cabin floor has a 3" joggle behind the main
lower carrythru tubes. Amazing thing is all the attach gear, struts,etc held up to this even though the float bottoms are pushed in a good
atfrom the forward bulkhead to the step area. On one the float is buckled
adventure!the step and the step bottom is blown apart at the rear step bulkhead.
I'll pass around a few pictures when I get the stomach to downsize them.
Sent: Thursday, August 12, 2004 5:43 PM
Subject: Re: round engine rebel / factory tour / Wayne's boring
brakes.Welcome back Wayne. It sounds like you had a close call with the
Gladit all turned out fine and sounds like you all enjoyed yourselves.
Bruce
List archives located at:
