I'm totally lost
Posted: Fri Feb 17, 2012 5:19 pm
Received: from the-benson-s
(216-164-239-170.s551.tnt10.lnh.md.dialup.rcn.com
[216.164.239.170])
by smtp2.erols.com (8.8.8/8.8.5) with SMTP id QAA14789
for <murphy-rebel@dcsol.com>; Sun, 11 Jul 1999 16:03:23 -0400 (EDT)
Message-ID: <003a01becbd7$26771c60$e1efa4d8@the-benson-s>
Subject: Re: I'm totally lost
Date: Sun, 11 Jul 1999 15:54:10 -0400
MIME-Version: 1.0
Content-Type: text/plain;
charset="Windows-1252"
X-Priority: 3
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook Express 4.72.3155.0
X-MimeOLE: Produced By Microsoft MimeOLE V4.72.3155.0
Date: Sunday, July 11, 1999 1:59 PM
Subject: I'm totally lost
Joel:
In my Rebel serial # 171, the pulleys attach to bulkhead "D", and the floor
ends there also. Today I am installing the brake/rudder pedals so I can't
help you with the cable problem etc.
Lonnie
[216.164.239.170])
MIME-Version: 1.0
X-Priority: 3
Joel:
Lonnie
theHelp! I absolutely cannot figure this out. The manual is contradicting
and vague. The answer is not here - hopefully it's out there somewhere. I
have two questions.
1 - Do the elevator pulley brackets attach to bulkhead 'D' or bulkhead 'E'?
2 - Does the floor end at bulkhead 'D' or bulkhead 'E'?
Bulkhead 'E' is the last 4 piece bulkhead - just in front of the one piece
one. The manual says attach the pulleys to 'D' but the picture looks more
like 'E'. The floor they sent me only reaches 'D', but the exploded fuse
drawing at the begining of the section shows flooring back to 'E'. The
manual shows floor channels back to 'E'. In the controls section they say
install cable guides all the way to the rear of the floor and the figure
shows the last ones at 'E' and no mention of any pulleys at all. I have a
picture I took at OSH down the factory Rebels tailcone, it's kinda dark but
I think the pulleys are on 'D' - and the cable runs up through a hole in
one piece bulkhead ABOVE the horizontal bulkhead. - No where in the manual
can I find where it says to cut this hole. Can someone give me a clue?
thank you very much!
Joel
Rebel #416
