Engine mount material size
Posted: Sat Feb 18, 2012 12:20 pm
I wonder if anyone can help me determine appropriate material sizing for
construction of an engine mount for an engine that weighs between 450
and 500 pounds and will produce up to 450 HP and 450 ft-lbs of torque.
Assuming I am using round steel tubing I need to know the size of tube
and wall thickness. I also need to know what thickness of plate should
be used for gussets, brackets, or other reinforcements.
As a starting point perhaps someone knows what the engine mount material
sizes are for a standard 300HP Lycoming O-540, or for the 400HP M14?
Thanks.
044SR
Thanks.
044SR
