Here's data I wrote down during a recent cross country flight. I was
going to upload the Excel file to the archives but the archives appear
to be inaccessible at the moment.
Ted Waltman
Moose N142SR 360 HP M14P-XDK
AVERAGES
Indicated Propeller
Indicated
Knots GPH MAP RPM EGT CHT Oil Temp Fuel
PSI Oil PSI OAT Altitude
90.8 16.5 23.6 1542 849 155 65 4 80
16 4687
ACTUAL FLIGHT DATA
Approx
Indicated Propeller
Indicated
92 14.7 23.0 1450 805 150 65 4 80
20 2,700
90 14.8 23.6 1500 867 150 72 4 79
20 4,500
91 15.0 24.0 1450 848 150 64 4 79
16 4,500
80 15.0 16.0 1710 866 160 63 4 80
15 3,500
78 15.3 18.9 1770 860 155 64 4 80
13 3,600
92 15.4 24.3 1500 872 170 76 4 78
23 4,500
91 15.5 25.1 1400 840 150 64 4 79
16 4,500
95 15.6 26.0 1400 859 160 62 4 80
13 9,500
92 15.8 24.8 1450 851 150 63 4 79
15 4,500
95 15.9 24.3 1500 863 160 66 4 80
13 9,500
92 16.2 24.9 1450 847 150 64 4 80
16 3,500
92 16.3 25.5 1410 835 150 62 4 79
15 4,500
92 16.5 25.1 1470 848 150 65 4 80
15 4,500
85 16.5 20.1 1800 860 160 64 4 80
14 3,500
94 16.9 25.9 1400 830 150 63 4 80
16 4,500
83 17.1 20.1 1770 865 155 64 4 80
14 3,500
98 17.5 25.8 1450 832 150 68 4 80
16 3,500
90 17.6 28.1 1340 833 160 64 4 80
13 9,500
92 17.9 22.4 1800 865 160 64 4 80
14 3,500
97 18.0 26.2 1450 833 160 65 4 79
15 4,500
98 18.1 27.0 1400 833 150 63 4 80
16 4,500
82 18.2 17.6 1790 860 160 63 4 79
15 3,500
98 18.7 23.9 1810 865 160 65 4 80
14 3,500
Moose flight data
Moose flight data
Hi Ted !
Your cruise speeds seem quite low - have you checked them agaist
a GPS ?? Did you ever try a photocell tach to check that the rpm
you are reading is indeed the prop rpm ??
I seem to remember getting cruise more like 120 kt at about
2000 rpm .... been a while though, so I'm a bit fuzzy !
Ted Waltman
AVERAGES
Indicated Propeller
Indicated
16 4687
ACTUAL FLIGHT DATA
Approx
Indicated Propeller
Indicated
20 2,700
20 4,500
16 4,500
15 3,500
13 3,600
23 4,500
16 4,500
13 9,500
15 4,500
13 9,500
16 3,500
15 4,500
15 4,500
14 3,500
16 4,500
14 3,500
16 3,500
13 9,500
14 3,500
15 4,500
16 4,500
15 3,500
14 3,500
Moose flight data
I do have a GPS in the plane; ground & true airspeed were indeed higher,
but winds/temp/altitude of course influence those. That's why I was/am
monitoring indicated speed. Using the E6B feature on the GPS, and
looking at the headwind/tailwind component, the indicated airspeed vs
ground speed seemed reasonable. Nonetheless, I'll be more diligent
about tracking these #'s too in my next flight(s).
I haven't used a photocell tach yet; that's next on my list. I did talk
to the builder, though, who confirmed that I'm seeing prop rpm on the
engine monitor.
Wow, I wish I was getting 120K at 2000 (engine) or 1400 prop rpm (lowest
setting that seems "right" on my plane). Engine / prop start growling
below 1400 prop rpm.
Thanks!
Sent: Friday, June 11, 2004 10:10 AM
Subject: Re: Moose flight data
Hi Ted !
I seem to remember getting cruise more like 120 kt at about 2000 rpm
engine monitor.
Thanks!
Hi Ted !
Ted Waltman
AVERAGES
Indicated Propeller
Indicated
16 4687
ACTUAL FLIGHT DATA
Approx
Indicated Propeller
Indicated
20 2,700
20 4,500
16 4,500
15 3,500
13 3,600
23 4,500
16 4,500
13 9,500
15 4,500
13 9,500
16 3,500
15 4,500
15 4,500
14 3,500
16 4,500
14 3,500
16 3,500
13 9,500
14 3,500
15 4,500
16 4,500
15 3,500
14 3,500
Moose flight data
Ted I thought yours was 400hp?
Waltman
Sent: Friday, June 11, 2004 10:19 AM
Subject: RE: Moose flight data
engine monitor.
Thanks!
Hi Ted !
Waltman
engine monitor.
Thanks!
Hi Ted !
