Plastic Float Access Cover Fix
Don't know if any of you float fliers have been breaking these,
but there may be a fix available for about $10 CAD if we can get
enough volume. Someone local here has arranged to have some SS
retainers fabricated if we can get enough volume. I will try to
describe them, since no pictures are available.
They are short round tubes the same diameter as the raw hole in
the float top. The tops have about a 1 inch outside flange just
large enough to cover the screw holes. The bottoms have a small
inside flange that fits just under the round plastic pieces where
the plastic caps screw into. These SS retainers then fit into the
float top raw hole first, and then you place the plastic cap
assemblies on top and inside. The top flange gives support to the
plastic flanges which also break when you step on them, but most
importantly the small bottom inside flange supports the bottom of
the plastic that the caps screw into, to prevent that plastic
breaking when someone steps on the caps.
Clear as mud? If anyone is interested, please let me know, and
we'll see if we can get enough volume to get these made at a
decent price. You can reply off list if you like.
Not sure exactly, but assume because they would be stronger.
[mailto:mike.davis@dcsol.com]On Behalf Of Bob
Fisher
Sent: Wednesday, May 26, 2004 7:02 PM
Subject: Re: Plastic Float Access Cover Fix
hi walter i wonder why they are made of SS instead
of aluminum ? fish
Sent: Wednesday, May 26, 2004 8:51 PM
Subject: Plastic Float Access Cover Fix
breaking these,Don't know if any of you float fliers have beenif we can getbut there may be a fix available for about $10 CADhave some SSenough volume. Someone local here has arranged towill try toretainers fabricated if we can get enough volume. Iraw hole indescribe them, since no pictures are available.
They are short round tubes the same diameter as theflange justthe float top. The tops have about a 1 inch outsidehave a smalllarge enough to cover the screw holes. The bottomspieces whereinside flange that fits just under the round plasticfit into thethe plastic caps screw into. These SS retainers thensupport to thefloat top raw hole first, and then you place the plastic cap
assemblies on top and inside. The top flange givesthem, but mostplastic flanges which also break when you step onthe bottom ofimportantly the small bottom inside flange supportsknow, andthe plastic that the caps screw into, to prevent that plastic
Clear as mud? If anyone is interested, please let me*------------------------------------------------------we'll see if we can get enough volume to get these made at a
-------------------**------------------------------------------------------To unsubscribe from this list go to:
hi walter i wonder why they are made of SS instead of aluminum ? fish
*-------------------------------------------------------------------------*Don't know if any of you float fliers have been breaking these,
The lower flange is actually the one that is needed the most, as
when the cap is stepped on, it gradually breaks away the plastic
female bezel ring from the top piece. I have had both areas
break, but when the cap starts caving in, you have to replace
them. I expect the weight to be very light.
The only other option to this problem (that I know of) is to make
separate aluminum covers which has been discussed here before and
I know Wayne uses. But if you want to retain the quick removable
cap covers, this might work.
Thanks, and will keep you informed.
klehman@albedo.net
Sent: Thursday, May 27, 2004 5:08 AM
Hi Walter
I am definately interested. There has been enough
comments about this
problem that I was not planning to use the screw in
covers unless a
reinforcement of some kind for the female bezel was possible.
They'd have to be kept fairly light if made of SS
instead of aluminum of
course and at that low price it sounds like you are
talking about a
stamped out bezel ring that goes under the existing
female plastic bezel
ring. That sounds like an elegant solution. I would
have guessed that
the lower flange was not needed as long as the top
flange gives enough
rigidity. If the top flange doesn't flex when stepped
on I would guess
the plastic won't break, but it's awhile since I
actually looked at the
pieces.
Walter Klatt wrote:breaking these,Don't know if any of you float fliers have beenif we can getbut there may be a fix available for about $10 CADhave some SSenough volume. Someone local here has arranged towill try toretainers fabricated if we can get enough volume. Iraw hole indescribe them, since no pictures are available.
Clear as mud? If anyone is interested, please let mewe'll see if we can get enough volume to get these made at a
OK, Nige, you're on the list. Yeah, been flying regularly on the
weekends, but it has all been local so far this year, mostly out
to the lake. We've had great spring weather so far, and I just
hope it's this good in July when I will have more time off from
work to do some longer trips. How's your project coming? Is that
diesel still looking good? Phil here got his Elite flying.
N.Smith
Sent: Thursday, May 27, 2004 6:54 AM
Subject: RE: Plastic Float Access Cover Fix
Hi Walter
Can you add me to your list...sounds like worth having
before I start
building.
Hope the float seasons going well for you.
Nigel
Derby
England
Sent: 27 May 2004 14:33
the most, as
the plastic
is to make
before and
removable
plastic cap-----Original Message-----
klehman@albedo.net
Hi Walter
comments about this
covers unless a
talking about a
have guessed that
flange gives enough
on I would guess
pieces.
They are short round tubes the same diameter as theflange justthe float top. The tops have about a 1 inch outsidehave a smalllarge enough to cover the screw holes. The bottomspieces whereinside flange that fits just under the round plasticfit into thethe plastic caps screw into. These SS retainers thenfloat top raw hole first, and then you place thethat plasticsupport to theassemblies on top and inside. The top flange givesthem, but mostplastic flanges which also break when you step onthe bottom ofimportantly the small bottom inside flange supportsthe plastic that the caps screw into, to preventmade at aknow, andbreaking when someone steps on the caps.
Clear as mud? If anyone is interested, please let mewe'll see if we can get enough volume to get thesedecent price. You can reply off list if you like.
Hi Walter
I am definately interested. There has been enough comments about this
problem that I was not planning to use the screw in covers unless a
They'd have to be kept fairly light if made of SS instead of aluminum of
course and at that low price it sounds like you are talking about a
stamped out bezel ring that goes under the existing female plastic bezel
ring. That sounds like an elegant solution. I would have guessed that
the lower flange was not needed as long as the top flange gives enough
rigidity. If the top flange doesn't flex when stepped on I would guess
the plastic won't break, but it's awhile since I actually looked at the
pieces.
pieces.
Hi Walter !
This does sound like a great fix - would have to go on first,
though - and my floats are already finished.... :-(
There is another fix - not a pretty, but easy enough -
just cut a circle of clear Lexan about 1/2" larger diameter than the
removable cover and fasten it to the top of the cover (couple of bolts ?).
Because it hangs out over the support ring, it transfers load
from the center of the cover (= the threads inside the support ring)
to the broad top surface of the ring itself - the cover can't be pushed
in through the hole ! You do have to cut a couple of holes in the Lexan
to open up the finger holes to twist off the cover ...
I had considered a full strip of 1/8" Lexan the full width and
most of the length of the float top, with traction paint on it, to
cover all of the covers, but it might be a bit more awkward for
inspections (if you don't have pumpouts ...).
*-------------------------------------------------------------------------*The lower flange is actually the one that is needed the most, as
klehman@albedo.net
Hi Walter
comments about this
covers unless a
talking about a
have guessed that
flange gives enough
on I would guess
pieces.
Hi Walter I'm good without them for quite a while. Murphy must have known
the sea dog covers weren't very strong because they sent about a dozen
spares with my kit.
spares with my kit.
DrewDon't know if any of you float fliers have been breaking these,
OK, you're on the list.
And to clarify for everyone, the $10 CAD is per cap, not for the
whole set.
Will keep you informed.
whole set.
Rebflyer@aol.com
Sent: Thursday, May 27, 2004 6:33 PM
Hi Walter, I'm interested! Give me an idea on the
price for the final decision, but it sounds good. I do
like the easy inspection the plastic covers give, but
hate the breakage.
Curt
Hi Walter
Can you add me to your list...sounds like worth having before I start
building.
Nigel
Derby
England
building.
Nigel
Derby
England
klehman@albedo.net
Hi Walter
comments about this
covers unless a
talking about a
have guessed that
flange gives enough
on I would guess
pieces.
Hi Walter, I'm interested! Give me an idea on the price for the final decision, but it sounds good. I do like the easy inspection the plastic covers give, but hate the breakage.
Curt
Curt
Hi Walter
Put me on the list as well .
Dale
Dale
If you remember this from last summer, Julius (that's his amphib
Rebel on the May Kitplanes cover) is now going to get another run
of these done now, and needs confirmed orders. I know a number of
you were interested back then, but some of you may have found
other alternatives. I have been using mine since last summer, and
they definitely did the trick for me. So those that still want
them, please let me know, either on or off the list, and I will
pass it on to Julius.
Of
Sent: Wednesday, May 26, 2004 5:51 PM
Of
I have found that the Beckson DP50 should work. Per the specs they
should fit within the existing holes.
Here is a link:
http://www.beckson.com/twistdp.html
I have found a supplier here in Canada that is to supply them for around
$10 each. Beckson has assured me that they will support weight (people
stepping on them) and not break.
Thank you,
Del Schmucker
Information Systems Manager
807-223-1254
807-221-8769 Cell
807-223-4703 Fax
del.schmucker@kpdsb.on.ca
www.kpdsb.on.ca
Sent: Sunday, April 24, 2005 10:41 PM
To: Rebel-Builders
Subject: FW: Plastic Float Access Cover Fix
Of
Here is a link:
Thank you,
Del Schmucker
807-223-1254
807-221-8769 Cell
807-223-4703 Fax
www.kpdsb.on.ca
To: Rebel-Builders
Of
These might be lighter and have no corrosion issues (stainless ring) for
a new installation.
Which I guess begs the question whether anyone has tried them or at
least had a good look?
The ones from MAM are also probably satisfactory on a solid deck that
doesn't flex.
a new installation.
doesn't flex.
Here is a link:
Thank you,
