impression (from the builder) that the empty weight CG is at the wing
leading edge. I believe the 250lbs of ballast he has been flying with
in the cargo space is to make triming it out easier. Again, I'll verify
and report back.
Don Boardman
Sent: Friday, May 14, 2004 8:56 AM
Subject: Moose flight report & purchase
HI Ted,
Congratulations on your purchase. Don't feel bad about not building your
Moose. For my partner and myself building is simply a necessity to end
up with the final product. If I had a magic wand I would have waved it
over the pile of parts the first day and puff, instant Moose! Purchase,
puff, instant Moose. Good for you.
Randy and I are apron six weeks or so away from first flight.
We certainly would be interested in detailed flight experiences. ThanksIf folks are interested (let me know), I'll report my detailed flight
experiences as I get checked out by the owner in a couple of weeks.
Landings should be interesting!
Ted, was this to state that the empty weight CG was at the leading edge?I'm told the CG is at the wing leading edge and
that one is wise to put some ballast in the baggage area if flying
alone to keep things well within limits.
I have seen two sets of numbers from Murphy for flying CG range. 9" to
20.4" and 9.5" to 21.38" aft of the leading wing's edge.
Was the 250 lbs. in the baggage area for demonstrating load carrying
ability? Do you know how much and where ballast was needed for solo
flight?
Once again, congratulations and welcome.
Regards,
Don Boardman
& Partner, Randy Bowers
N622D Double Duce Delta Moose
#130 M-14PF 400HP, MT-Prop/Beta, Aerocet 3500 amphibs
Delta Lake, Rome, NY
