Thanks Al
Don Boardman
Thanks Al
Post by Don Boardman » Sat Feb 18, 2012 9:12 am
Thanks Al, Don
Reply-To: murphy-rebel@dcsol.com
Date: Mon, 19 Apr 2004 12:40:54 -0700
Subject: Re: Seafins - Stab Mods
I measured the seafins and they are .080 thick.
Al
Sent: Monday, April 19, 2004 10:35 AM
Hi Don,
I will measure to be sure and let you know but I think .063.
Al
Sent: Monday, April 19, 2004 10:30 AM
Hi Al,
We are getting close!
What thickness did you use for your Seafins?
Don B.
for
new
rivets
Archives located at http://www.dcsol.com:81/default.htm
Don Boardman
Thanks Al
Post by Don Boardman » Sat Feb 18, 2012 9:50 am
Thanks Al, I'm off for another day at the Mooseworks.
Don
Reply-To: rebel-builders@dcsol.com
Date: Sun, 12 Dec 2004 21:51:43 -0800
Subject: Re: Al Paxhia, Panel Rivets/Water Rudders
Hi Don,
The rivets that sheared were the ones that attach the instrument panel to
the door posts. I did go up one size to 5/32" and interleaved with 1/8"
rivets. Note the reason they sheared was the v-brace had broken and was
still doing water operations in rough water. I think the panel would have
been just fine if the v-brace had been there. The real issue is strengthen
the upper fittings on the v-brace. I welded on a thicker tab and welded a
gusset on the side of the tab.
Water rudders should have springs in the cables to the air rudder and tight
enough to keep tension in the cable. The spring will allow the air rudder to
operate if the water rudder becomes jammed.
Al
Sent: Sunday, December 12, 2004 7:31 PM
Subject: Al Paxhia, Panel Rivets/Water Rudders
Hi Al,
I hope I am remembering this right. Did you indicate that you had some
panel
rivets shear with a water landing?
If so, which rivets?
Did you replace with larger rivets?
What was your fix?
I am also installing my water rudder cables. I am trying to determine how
tight they need to be (or loose they need to be) I would appreciate what
your experience in this area has been. Al, others
Getting closer every day,
Don B
