Rebel-Factory Wingtip Install
Posted: Sat Feb 18, 2012 9:09 am
I have the stock Rebel wingtips which I am in the process of installing with
rivets, per the builder's manual. I am aware of some builder's using
nutplates, but I am going with the manual on this and using rivets.
For the wingtip install, the manual calls out for drilling a hole (between
the existing flush rivets) after every second rivet in the outboard rib
flange.
But, the existing flush rivets in the outboard leading edge rib are currently
spaced (factory drilled)from 5/8ths to 3/4 inch. To drill an additional rivet
between these, violates established rivet spacing practices of AC 43.13-1B.
I'd be interested to know what others have done. The only other alternative I
see is to drill out some of the existing flush rivets to use for mounting the
wingtip, but that would require flattening the dimpled hole and I don't know
if that is an accepted practice or not.
I would appreciate any comments.
Roger Hoffman #687R
Eugene, OR USA!
flange.
Roger Hoffman #687R
Eugene, OR USA!
