Sloshing Compound Identification
rebel
Post by rebel » Sat Feb 18, 2012 12:09 pm
The stuff mam gets is from seal pac! Same as their proseal. part # cs 3600
On 4/12/2004 7:52 PM, OIFA@IRISHFIELD.ON.CA wrote to MURPHY-REBEL:
-> Received: by dcsol.com (Wildcat! SMTP Router v5.7.450.9b13)
-> for murphy-rebel@dcsol.com; Mon, 12 Apr 2004 16:48:08 -0800
-> Received: from ([207.164.81.3]) EHLO=frodo.csolve.net
-> by dcsol.com (Wildcat! SMTP v5.7.450.9b13) with SMTP
-> id 131652500; Mon, 12 Apr 2004 16:48:06 -0800
-> Received: from 207.35.14.29.hub5.csolve.net ([207.35.14.29]
helo=celeron266a)
-> by frodo.csolve.net with esmtp (Exim 4.24)
-> id 1BDC5h-000K3Q-QT
-> for murphy-rebel@dcsol.com; Mon, 12 Apr 2004 20:47:54 -0400
-> Message-ID: <001101c420f0$f19c51d0$e401910a@celeron266a>
-> From: "Wayne G. O'Shea" <oifa@irishfield.on.ca>
-> To: "Murphy Rebel Builders List" <murphy-rebel@dcsol.com>
-> Subject: Sloshing Compound Identification
-> Date: Mon, 12 Apr 2004 20:47:47 -0400
-> Organization: O'Shea's Irish Field Aviation
-> X-Orig-MIME-Version: 1.0
-> X-Priority: 3
-> X-MSMail-Priority: Normal
-> X-Mailer: Microsoft Outlook Express 5.50.4522.1200
-> X-MimeOLE: Produced By Microsoft MimeOLE V5.50.4522.1200
-> X-Antivirus-Remover: Message was filtered through wsMailGuard (wsAV)
-> Not looking for a lecture...I know better than to use the stuff...but I
have
-> a guy asking about it to redo what someone else started.
-> Does anyone know who's sloshing compound is red?? Randolph's is yellow and
-> white.
-> I have found the red stuff in a few Rebel tanks, but don't know who the
-> manufacturer is...can someone help here?
-> THANKS!
-> Wayne
Post by Wayne G. O'Shea » Sat Feb 18, 2012 12:09 pm
Not looking for a lecture...I know better than to use the stuff...but I have
white.
THANKS!
Legeorgen
Post by Legeorgen » Sat Feb 18, 2012 12:09 pm
Wayne,
I've seen the red stuff too but don't know who makes it. Kreem is another
brand but it's white as well. I used Kreem in my Kitfox and had to remove the
wings after two years and clean it out.
I had been soaking pieces of aluminum that was covered in Randolph in a jar
of gas. These were pieces that were left over from the original Rebel kit
purchaser who used it to seal his leaks. I patched the tanks from the outside and
left the Randolph in the tank (I knew better) hoping it would stay as it had
not pealed off the pieces of aluminum I had been soaking in the jar after 18
months.
Well, the Randolph has since completely separated (three years later) from
the aluminum in the gas soaking jar and I am now waiting for the day it peels
off in a sheet from the wing tank and covers my finger screen. I keep a close
eye on the stuff but it's only a matter of time.
Tell the guy to do himself a favor and fix the tank the right way now and be
done with it. Sloshing the tank with a few gallons of MEK will clean it out.
It takes about two or three guys to flip the wing over several times before
emptying it and repeating the process until it runs out clear.
Bruce 357R
Legeorgen
sorry for the lecture, Wayne, but I couldn't help myself!
Bruce
Airplane is a Baking Deuce, so might just be a fuselage tank or similar...I
don't know for sure.
When you pour the MEK in to get rid of the sloshing compound, does it not
destroy the Proseal filets as well??
Sent: Monday, April 12, 2004 10:00 PM
Subject: Re: Sloshing Compound Identification
Wayne,
jar
outside and
had
18
months.
peels
close
be
out.
before
Bruce 357R
Legeorgen
The Kitfox had fiberglass tanks and the MEK wasn't in long enough to destroy
the glass but the Rebel and the Proseal would might be a problem. The tank
sealers dissolve quickly with the MEK but it might not be in long enough to
dissolve the proseal, completely...maybe
Bruce
"Maybe"s don't bother me when it's the Zetor tractor!! :o))
Sent: Tuesday, April 13, 2004 10:17 AM
destroy
Bruce
Jerry Purdom
Post by Jerry Purdom » Sat Feb 18, 2012 12:09 pm
Wayne:
Sealpak no.cs3600-mil-s-4383c is a red sloshing compound from Flamemaster
corp./chem seal div.
Ph. 316-942-6211
THANKS
jerry
Sent: Monday, April 12, 2004 5:47 PM
have
white.
THANKS!
THANKS! Jerry, I will pass that on to the gentleman in question. Wayne
Sent: Thursday, April 15, 2004 12:11 PM
Wayne:
Ph. 316-942-6211
THANKS
jerry
have
white.
THANKS!
