"Blow in" corrosion protection. was building in th
klehman
Post by klehman » Sat Feb 18, 2012 9:09 am
Hi ???
Commercially built aircraft with more corrosive 2000 series aluminum
alloys benefit from spraying in something every couple of years. I
prefer the non-hardening Corrosion-X or ACF-50. It wicks into crevices
and neutralizes existing corrosion. There is discussion in the archives.
I made sure I had access to every internal compartment. A 3/16" hole and
a plug in floor spaces for example. Personally I'd also prime the
interior if planning to play in seawater.
rebel@dcsol.com wrote:
Bobp said "You can always blow in a mist of
Northern Shield or Boeing D-29, or similar, AFTER everything is assembled" I
had never heard of this. Can you give any more details? Is this an
alternative to painting/priming for the major portions of interior surfaces?
I still don't know if I should be worried about this as much as I am, but I
definately see saltwater in my future.
