Jean,It only required 4 reamers - 3/16, 1/4, 5/16 and 3/8. These where
straight flute " hand reamers" which I ran in a variable speed rechargable
drill. It does make a much better job. - Bob J Rebel 652
I would add that most AN bolts are a bit undersized and to get a snug fit,
which is usually desirable, you may need to use undersized reamers. For
example in the 3/16 inch family we have .1855, .1865 .1870 and .1875.
We always start with the smallest reamer and see how the bolt fits,
enlarging as needed to get a tight fit. Also note that all your bolts are
not the same size. Micing them will show size. If one bolt is a little loose
sometimes trying others will provide a tight fit.
We purchased imported reamers from:
http://www.mscdirect.com/
they were reasonably priced.
Don B.
Moose 130
