DUAL BRAKE
Posted: Sat Feb 18, 2012 9:05 am
by Jean Poirier
When I ordered my rebel kit, I did'nt ordered the dual brake kit.
But now I think it will be a good idea to have dual (no time yet on tail wheel). MAM list the dual kit at $375.00 usd. In the manual, the plan show the plan/instruction for dual retrofit or single set of brake pedal. The only difference I can see, is just couple of tube, small brachets, cotter pin, bolt etc.... The $375.00 is like a warning light to me.... do I missed something? If not, I will fabricate thoses parts and save....
I am building a Rebel but I know someone wuo is building a Elite, do they have the same brakes pedal? If it is the same, I can use his parts for copy? Someone cant hel me..... I am waithing the firts inspection (tail, aileron) and I want to finish those parts (final rivething, trim installation) before to start the wings. So if it is too long, I will make the brake parts until.
Jean
Rebel 747R
DUAL BRAKE
by klehman
Hi Jean
Yet another option is to pick up a cheap set of used brake cylinders at
Sun&FUN and make two extra brake pedals. Either way I think "airparts"
in the flymarket usually has cheap short lengths of 4130 tubing but they
may sell out by later in the week. I picked up a parking brake valve as
well. There was no visible wear on the used parts so I put new buna
o-rings in them and installed them. They will get removed when 119 goes
onto floats anyway. I haven't taken a good look at the mechanical
interconnect system to see which approach I like better or which is less
work.
Jean
Rebel 747R
DUAL BRAKE
Posted: Sat Feb 18, 2012 9:09 am
Jean.....the cheapest option (and probably the best working set up) is to go
to a salvage yard and get a full set of pedals out of a Cessna or
Beechcraft. The AULA Rebel that I am refurbing right now has a set, that I
believe came out of a Beechcraft, and they are the cats meow..... compared
to MAM's set up.
If you want some pics just ask!
Sent: Monday, March 22, 2004 8:23 AM
Subject: DUAL BRAKE
Jean
Rebel 747R
DUAL BRAKE
by Jean Poirier
Hi Wayne!
Cessna parts.... just for the right side or for both side... Complete
with cylinder and everything or just the pedal?
Thank'
Jean
p.s.: will you be at Sun'fun..... I will be there with a builder of Laval
who is building a Elite very slowly! (it is a subliminal message for him
Sent: Tuesday, March 23, 2004 10:16 AM
Subject: Re: DUAL BRAKE
go
to MAM's set up.
Subject: DUAL BRAKE
tail
save....
they
make
Jean
Rebel 747R
DUAL BRAKE
by Jean Poirier
Wayne...
yes some picks.....
Jean
go
to MAM's set up.
Subject: DUAL BRAKE
tail
save....
they
make
Jean
Rebel 747R
DUAL BRAKE
Jean...take the entire assembly! Pedals/cylinders/mounting blocks and all
for dual control. There's usually only one set of cylinders on a nice set...
that are operated by pushing either sides pedals. Using double sets of
cylinders plumbed in series only adds to the cost/maintenance/leak
possibilities.
Sent: Tuesday, March 23, 2004 12:09 PM
Hi Wayne!
Thank'
Jean
go
compared
to MAM's set up.
Subject: DUAL BRAKE
tail
plan
pedal.
save....
they
(tail,
make
Jean
Rebel 747R
