SR stick installation
Posted: Sat Feb 18, 2012 12:05 pm
I'm installing the sticks in my SR-2500 and seem to have a problem. First,
they seemed to be far too tall for one to sit comfortably with hand on leg in
flight. I cut one down 3.5 in. in height and this seemed much better and still
left what seems to be adequate "stick force". The second problem is that
even with a shortened stick, with full left or right aileron and full forward
stick, the grip(s) will hit the side, angled instrument panel(s). Elevator down
stop is set to give approx. 23 degrees nose down elevator. I do not have
wings or ailerons installed, but the aileron stops on the stick base seem to be
set at a reasonable position. The stick hitting the panel (actually hits
several switches on the pilot's side angled panel) is not acceptable. Perhaps
bending the sitick some more would be an option. The design appears to be a
problem or perhaps I have "missed something" in my construction. Any suggestions
would be most helpful.
Charlie Starr
SR-2500 #65
Charlie Starr
SR-2500 #65
