Thanks so much for the Sico recommendation. I also noted today that JetGlo,
a urethane that I had good success with on a 172 some years ago, comes in a
KwikKit pckage for small areas and touchups. Probably costs a fortune
however.
Best wishes,
Jeffrey
Sent: Monday, March 01, 2004 7:03 AM
Subject: Re: Cowling Question
use,Hello Jeffrey!
If I understand your question about paint, epoxy paint should never be use
as a top coat. After couples of month paint will start to come dull.
Corrosion resistance of the epoxy primer/paint is very goog but resistance
to UV is minimal (for the finish). Have a look of Sico aircraft paint!
Very good price and design for aircraft! But no matter which paint you
blafollow the manufacturer recommandation! Always! Do not listen the "bla
bla", and their miracle recipe. Good luck
Jean
Rebel 747R
