Dremel was Re: Air Drills
Posted: Sat Feb 18, 2012 12:00 pm
Hey, All,
Dremel also makes a 3-jawed chuck, which eliminates the collets, which are a
pain when you're using different sized drills.
Clint
Sent: Saturday, February 28, 2004 6:10 AM
Subject: Dremel was Re: Air Drills
Clint
*-------------------------------------------------------------------------*Hey Bob,
I guess you know there is now (for a couple of years actually) an
accessory 90 degree head for the Dremels. If you use collet sized
cutters or drill bits, it only adds less than an inch to the shank
length, and they are surprisingly strong.
Take care.
Brian Lawson,
Bothwell, Ontario.
XXXXXXXXXXXXXXXXXXX
On Fri, 27 Feb 2004 21:34:53 -0500, you wrote:
IndustrialHi Mike !
Gee, our idea of optimum would be about 6,000 rpm -
that 4,500 rpm model sounds just fine !! :-)
Those speedy Dremels are handy in tight spots, also
great with the little sanding drums ....
....bobp
----------------------------orig.-------------------
On Friday 27 February 2004 08:51 pm, you wrote:aluminium is something on the order of 30k rpm which is well beyond theI have read that the optimium speed for drilling small holes in thin
drills that I have seen There is a 15,000 rpm drill made by USwill itavailible as well as a 4500rpm model. If I get the 15,000 rpm model,havehave enough torque for my needs or will I want a second air drill (Irecommend?numerous electric and cordless drills)? What do you guys use and(fastWhich drills have the best trigger control? I will be building a Moose*------------------------------------------------------------------------build)..Mike
MU-2
-**------------------------------------------------------------------------To unsubscribe from this list go to:
