Odyssey battery terminals
Post by Ralph Baker » Sat Feb 18, 2012 8:55 am
The PC680 terminals are on top and are drilled and tapped holes. I
think they are 5mm. An internet search of "Odyssey batteries" will turn
up a website with dimensions and terminal data. You use a ring terminal
and a proper screw, flat, and star washer. I prefer stainless and a
good hardware store should have what you need. Remember, these
batteries need to be charged at 14.4 volts to accept a full charge.
They can be mounted in any position except terminals down. The metal
case version does not need a battery box.
Elite 624E
klehman
Post by klehman » Sat Feb 18, 2012 8:55 am
I don't see why a battery box would be needed for any of these unless it
made mounting easier. These things aren't supposed to leak even if
broken open...
Elite 624E
