1800 amphib spray rails
Wayne,
Do YOU put the spray rails alongside the step on all of your floats? In
some of the pictures it looks as if there aren't any spray rails next to
the step. I just put the first one on, & it looks pretty flimsy to
me--just waiting to get bent the first time you pull it up on a beach.
Would like your or anybody else's opinion on them. Thanks!
Clint Passeno
Petoskey, MI
Clint Passeno
Petoskey, MI
I have mine on exactly as per stock factory specs, and am OK with
them as they are. They are supposed to help give you some lift at
the back for faster take-offs. How much difference it makes, not
sure. So far, after a couple of years float flying, no damage on
docks or barnacles. You do need to be careful not to cut your
shins, though, when working around them in the hangar.
Sent: Saturday, January 31, 2004 12:05 PM
Subject: Re: 1800 amphib spray rails
Wish you guys would stop directing questions directly
at me and send them to
nobody in general..guys/gals etc instead. This isn't
my mail list and there
are many others here that can answer these questions
as well. When they are
addressed at me it kind of makes me obligated to
answer and I'm trying to
get back to reality around here by spending the
"spare" time in the shop,
with family (or plowing friggin snow!) and off this
damn computer that
currently ties up 8+ hours of my day! That said...
The "spray" rails along the step do two things. They
channel air under the
floats to help lift the airplane on take off and the
water spray beating
down against the water helps break the surface
tension/hold in calm water as
well. Not sure what pictures you are looking at, but
they are on any Rebel I
have had "hands on" with here. They will get damaged
of course, if you start
ramming docks etc with them. On Howard's we left the
inside ones full width
and cut the outside ones down to about 70%.... so they
weren't quite as
flimsy and so they didn't stick out as far to sustain
dock rash damage.
From: "Clint and Beverly Passeno" <passenoc@gtlakes.com>
Cc: <bowmanout@yahoo.com>
Sent: Saturday, January 31, 2004 12:58 PM
Subject: 1800 amphib spray rails
of your floats? InWayne,
Do YOU put the spray rails alongside the step on allspray rails next tosome of the pictures it looks as if there aren't anypretty flimsy tothe step. I just put the first one on, & it looksit up on a beach.me--just waiting to get bent the first time you pull*------------------------------------------------------Would like your or anybody else's opinion on them. Thanks!
Clint Passeno
Petoskey, MI
-------------------*https://rebel:builder@www.dcsol.com/default.htmTo unsubscribe from this list go to:
Archives located at*------------------------------------------------------To contact the list admin, e-mail mike.davis@dcsol.com
Archives located at
At 12:58 PM 1/31/2004 -0500, you wrote:
I put all 4 spray rails on my floats it really helps to pop the plane up
onto the step quickly. They are kind of flimsy but are well above the
bottom when beaching the plane. The real problem is docking without denting
the outside ones. I also gave myself a nasty cut on my toe while pumping
them out with the plane was beached
Hi ClintWayne,
Clint Passeno
Petoskey, MI
Wish you guys would stop directing questions directly at me and send them to
nobody in general..guys/gals etc instead. This isn't my mail list and there
are many others here that can answer these questions as well. When they are
addressed at me it kind of makes me obligated to answer and I'm trying to
get back to reality around here by spending the "spare" time in the shop,
with family (or plowing friggin snow!) and off this damn computer that
The "spray" rails along the step do two things. They channel air under the
floats to help lift the airplane on take off and the water spray beating
down against the water helps break the surface tension/hold in calm water as
well. Not sure what pictures you are looking at, but they are on any Rebel I
have had "hands on" with here. They will get damaged of course, if you start
ramming docks etc with them. On Howard's we left the inside ones full width
and cut the outside ones down to about 70%.... so they weren't quite as
flimsy and so they didn't stick out as far to sustain dock rash damage.
*-------------------------------------------------------------------------*Wayne,
Clint Passeno
Petoskey, MI
Can't remember exactly, as it was a couple of years ago now for
me, but do believe it matters. Aren't the ports labelled at the
back? Worst case, you'll have to do some trial and error.
Legeorgen@aol.com
Sent: Saturday, January 31, 2004 6:39 PM
How can I tell which side of the selector switch for
the 1800 floats is gear
up or down? Does It makes a difference on how I mount
it. I want the knob "up"
for gear up and "down" for gear down.
Bruce
Archives located at
Don't know Bruce, but if you don't get a good answer by tomorrow,
I can go out to my hangar and have a look. Just tell me exactly
what you want me to check. Not sure if I can get a digital pic
from behind the panel, but will try if you want. I also just had
a look at the manual, and figure 16.3.2 seemed to show how each
port was to be used. I think that's what I followed, and it
worked out OK.
worked out OK.
Legeorgen@aol.com
Sent: Saturday, January 31, 2004 6:55 PM
Ports are labeled pressure and exh (exhaust?) I think.
I can't test anything
until the switch and pressure gage are mounted. Then
it would be to late to
rotate it very easily.
Bruce
Archives located at
No problem. Sounds like you're almost there. Good luck.
*-------------------------------------------------------------------------*-----Original Message-----
Legeorgen@aol.com
Sent: Saturday, January 31, 2004 7:52 PM
Walter, you don't have to check your switch now but
thanks for the offer.
Bruce
Archives located at
How can I tell which side of the selector switch for the 1800 floats is gear
up or down? Does It makes a difference on how I mount it. I want the knob "up"
Bruce
Bruce
Ports are labeled pressure and exh (exhaust?) I think. I can't test anything
until the switch and pressure gage are mounted. Then it would be to late to
Bruce
Bruce
Walter, you don't have to check your switch now but thanks for the offer.
Bruce
Bruce
Bruce, "pressure" must remain the input from the pump and "ex" is drain to
the tank, so only leaves two options for lines A or B. The handle can be
moved in 90* increments if I remember right. Blow through the valve (or use
your blow off gun on your compressor) in through the pressure port and see
which a or b it comes out. Verify handle position and pick the port that is
an "output" when the handle is up and connect this to the line going to your
forward (rod end) of your cylinders. The down handle "output" port will be
plumbed to the rear (piston end) of all your cylinders.
Sent: Saturday, January 31, 2004 9:55 PM
anythingPorts are labeled pressure and exh (exhaust?) I think. I can't test
tountil the switch and pressure gage are mounted. Then it would be to late
*-------------------------------------------------------------------------*rotate it very easily.
Bruce
Walter,
If you get to your plane this weekend look at the position of the switch with
the gear down and tell me, if you can, what port the knob/lever is pointed
toward. Thanks.
Bruce
toward. Thanks.
Bruce
Thanks Wayne and Walter,
Between what you said and looking at the manual again I have it figured out.
Bruce
Bruce
