NOT about Mounting 1800 Floats????
George Coy
Post by George Coy » Sat Feb 18, 2012 11:52 am
Hey if you guys would change the subject line once in a while, it would be
easier in the future to see what the actual subject was about.
George
LisaFly99@aol.com
Sent: Saturday, January 10, 2004 11:00 AM
Subject: Re: Mounting 1800 Floats????
In a message dated 1/9/04 6:07:43 PM Central Standard Time,
SWSLOANLK@aol.com
writes:
Bruce!
I am using a 4to1 exhaust system into a central 6" by 18" long muffler.
The
whole muffler is wraped with a heat shroud and is ducted direct to the
cabin.
There is no carb heat!
Steve S
BRUCE & STEVE
could you please change the header. GOOD info, but it will never be found in
the archives.
Phil&Lisa Smith
#460R
N414D
Legeorgen
Post by Legeorgen » Sat Feb 18, 2012 11:52 am
Sorry guys,
It started out about the correct angle and methods to mount the 1800 floats
and migrated to Steve's test flights in his IO240 float equipped Rebel.
Bruce G
