Rebel Door Handles
Posted: Sat Feb 18, 2012 3:07 am
by Lonnie Benson
Curt,
I would like to use a "D" shaped handle on the inside of my doors, like the
ones I saw in your Rebel, but I am having trouble finding any. Can you, or
any one else on the list, help?
Lonnie
Rebel 171
Rebel Door Handles
by LisaFly99
In a message dated 12/16/03 5:52:45 PM Central Standard Time,
lonben@erols.com writes:
Lonnie
LONNIE
Take a piece of you're fuel line shape it the way you want flatten the ends
and rivet in place.
Phil&Lisa Smith
#460R
N414D
Rebel Door Handles
by Rebflyer
Hi Lonnie,
Sorry I cannot help you with a premade set, as we made our own. Bent the
handle out of 1/4" steel rod, and soldered 2 small bearings to that. The
cross bar that we attached them to was 3/8" rod drilled and tapped for # 6 screws.
The bearings allow the handle to swing from against the door in the closed
position to hanging down in the open position. Some day I'll get digital enough
to send pictures. (Maybe for christmas?) Curt
Rebel Door Handles
by CWS1932
I found two good D handles at Home Depot - evidently used as door opening
handles. After making a back plate and riviting to the forward door post on my
SR they work great
Charlie Starr
Rebel Door Handles
by gjohnson95667
-> Lonnie try these two sites for the latches: www.stealthaerospace.com
www.allegiscorp.com These latches contain the entre mechanism for securing
the door.
Greg
Rebel #479
-> Curt,
-> I would like to use a "D" shaped handle on the inside of my doors, like the
-> ones I saw in your Rebel, but I am having trouble finding any. Can you, or
-> any one else on the list, help?
-> Lonnie
-> Rebel 171
Rebel Door Handles
by Jones, Michael
lonnie
why dont you take a look at the pics i post on web rebel website under gull
wing door, my door systems fit within the 5/8 tubing, has flush paddle on
exterior and crannk handle on inside, works very well and just needs little
fine tuning to be perfect
regards
mike#007
From: gjohnson95667@dcsol.com [mailto:gjohnson95667@dcsol.com]
Sent: Thursday, December 18, 2003 10:53 AM
Subject: RE: Rebel Door Handles
the door.
Greg
Rebel #479
-> Curt,
or
-> Lonnie
-> Rebel 171
