Do you have info about "Brown tool"?
Jean
Rebel 747R
Sent: Friday, December 05, 2003 10:58 AM
Subject: [AVIS-NOTICE] Fw: flush avex rivet
forI have 120' countersinks with centering mandrels from Brown tool.
Jim
Sent: Thursday, December 04, 2003 12:43 PM
Subject: Re: flush avex rivet
prettyJean
120 degree countersinks are available in single flute and multi-flute
from tool suppliers but the ones that I have do not have a mandrel and
are not self centering. However a normal 118 degree drill bit will
finish the countersink a little better than just a 100 degree cutter and
help you get a flush surface after you rivet.
120 degrees seems to be common for non aviation blind rivets including
avex, pop, and the structural Q rivets.
Wayne G. O'Shea wrote:The Avex RV44's are actually 118 to 120 degrees, but the 100 c/s isnotclose and I have to admit that I've cheated a >few< times!
Sent: Thursday, December 04, 2003 11:07 AM
Subject: flush avex rivet
aileron. Murphy ask to contersink with a grind 1/2' drill but they dospecifid the rivets angle! I have use a microstop contersing cutter
*-------------------------------------------------------------------------*thosesolid rivet (100 deg.) It looks ok but is it? what is the degree forAvex flush rivet?
