M14 Air uses
M14 Air uses
Bill, you may have something there blowing up Otto Pilot with the air.
Could then throw him in the lake and use Wayne's new motor to putter around
on. I'll have to think about that one as I keep thinking the air could have
more uses...run a gyro?? Wonder if the flow from dump valve would be enough
to run through a small venturi for suction??
Scott
Scott
M14 Air uses
There's an idea aye! Keep the engine running and pump up your inflatable
boat from an airchuck on the fuselage! Feel sorry for the guy hanging off
the side of the float, while you taxi in circles around the lake though!!
From: "Scott & Leere' Aldrich" <flynski@mwutah.com>
Sent: Monday, November 17, 2003 7:59 PM
Subject: M14 Air uses
aroundBill, you may have something there blowing up Otto Pilot with the air.
haveon. I'll have to think about that one as I keep thinking the air could
enoughmore uses...run a gyro?? Wonder if the flow from dump valve would be
*-------------------------------------------------------------------------*to run through a small venturi for suction??
Scott
M14 Air uses
Doesn't the Yak uses air for a lot of things?
Your right no vacuum on the jets (oh, except the toilets on some..), gyros
are all electric (and most are ring laser with no moving parts).
Pressurization is bleed air from engines.
Maybe no wheels on amphib, just hover craft skirts.
Scott
Bill Delcambre
Sent: Tuesday, November 18, 2003 9:39 AM
Subject: Re: M14 Air uses
I doubt that there's enough air available to do the venturi thing. I would
probably just use a regulator to drop the pressure to a usable level and run
the gyros with that airflow. I doubt if they know whether the flow through
them is caused by a negative or positive pressure source. Probably need a
good filtration system, though. All told, still less expensive and more
reliable than a vacuum system. If the compressor failed (IMC), you'd have
quite a while to get to VMC, just using the reservoir. Don't jets and
turboprops use pressure systems, as opposed to vacuum sytems? (this is
really a question. I always assumed they didn't use vacuum pumps, but
rather bleed air pressurization)
Personally, I'm planning on some version of the solid state attitude
indicators. By the time I'm ready to get that stuff, I figure most of the
bugs will be purged.
You amphib guys ever thought about an air/hydraulic system for your gear?
No pump, wiring or reservoir. Just a cylinder with air on one side and oil
on the other. Or better yet; airbag actuation. No hydraulics at all. We
could do air actuated flaps.
Gettin stupid, huh?
Bill
Sent: Monday, November 17, 2003 6:59 PM
Scott
Bill Delcambre
Gettin stupid, huh?
Bill
Scott
M14 Air uses
Gettin stupid, huh?
Bill
Gettin stupid, huh?
Bill
Scott
M14 Air uses
Wayne! I'm disappointed. To do such a stunt as having a man hang onto the
float while doing donuts on a lake would be irresponsible! You'd waste gas
and irritate the tree huggers all over the lake. The correct procedure
would be to inflate the boat shortly before touchdown. That way you'd be
ready to attack the bass immediately after touchdown. :) Oh yeah, I
forgot; you 'Northern Exposure' types don't get many bass. That'd be
something like grunion, huh?
I'm thinking about mounting an airhose-reel on the belly.
Bill
Sent: Monday, November 17, 2003 7:29 PM
Bill
*-------------------------------------------------------------------------*There's an idea aye! Keep the engine running and pump up your inflatable
Could then throw him in the lake and use Wayne's new motor to putterhaveon. I'll have to think about that one as I keep thinking the air couldenoughmore uses...run a gyro?? Wonder if the flow from dump valve would beto run through a small venturi for suction??
Scott
M14 Air uses
Don't know much about Yaks. Bet George could shed some light. Close buddy
had a Nanchang and I can tell you that a BUNCH of stuff was pneumatic.
Starter, flaps, brakes, gear retract and maybe more. Interesting thing is
that he absolutely never had any trouble with any of the air systems. Those
things worked perfectly, every time. Any time I ask M14 guys their opinion
about electric starting, the reaction is the same; "why mess with the best
part of the engine!"
As for the hover craft skirts; I like the way you think! THIS is the
spirit of 'experimental aircraft'!
Bill
Sent: Tuesday, November 18, 2003 12:26 PM
Subject: RE: M14 Air uses
Bill
gyrosDoesn't the Yak uses air for a lot of things?
wouldare all electric (and most are ring laser with no moving parts).
Scott
Bill Delcambre
runprobably just use a regulator to drop the pressure to a usable level and
throughthe gyros with that airflow. I doubt if they know whether the flow
oilthem is caused by a negative or positive pressure source. Probably need a
*-------------------------------------------------------------------------*on the other. Or better yet; airbag actuation. No hydraulics at all. We
Gettin stupid, huh?
Bill
Scott
M14 Air uses
Now there's another great idea, a hose reel! You could use it as a water
skiing line for barefooting.... when the guy falls off the floats while
pumping the boat!!
As for Bass, we have lots up here. The town of Midland even held a
Bassmasters Pro tournament early this fall, that brought guys from as far as
Texas (as I could see by reading license plates on the 75 plus tow rigs
parked on the main drag).
From: "Bill Delcambre" <bdelcambre@cox-internet.com>
Sent: Tuesday, November 18, 2003 1:08 PM
pumping the boat!!
theWayne! I'm disappointed. To do such a stunt as having a man hang onto
gasfloat while doing donuts on a lake would be irresponsible! You'd waste
offand irritate the tree huggers all over the lake. The correct procedure
Bill
though!!the side of the float, while you taxi in circles around the lake
could)
Could then throw him in the lake and use Wayne's new motor to putteron. I'll have to think about that one as I keep thinking the air
*-------------------------------------------------------------------------*haveenoughmore uses...run a gyro?? Wonder if the flow from dump valve would beto run through a small venturi for suction??
Scott
