B for the STOL Cuff kit on the Rebel (or Elite)
Sent: Wednesday, November 12, 2003 7:34 PM
Subject: Re: Borer Prop for Rebel on Floats
ofProbably pretty close Bruce! I don't remember what gauge it was made out
*-------------------------------------------------------------------------*but by estimation the cuff has to be at least a 16" piece of aluminum
(likely wider) and there's 24' of it. That's a minimum of 2/3rds of a 12'
sheet of aluminum. Therefore if it's .020 = 9lb, .025 = 11.3lb, .032 =
14.7lb for the cuff skin, then add a few pounds for rivets, the foam ribs
and adhesive. Add to that as well the wing fences made out of .063"? (I
believe) are good for 3 lbs/set.
Sent: Wednesday, November 12, 2003 7:08 PM
leadingThe STOL kit can't weigh that much. It's only like an extra layer ofedge skins. Well, maybe it can act as the thicker Elite leading edge and
increase the gross to 1850 lb. Unofficially of course.
Bruce
