bolt holes
bolt holes
Post by Mike Davis » Fri Feb 17, 2012 8:18 pm
Received: from ns.idirect.com (ts3-16t-41.idirect.com [209.161.234.169])
by orion.idirect.com (8.9.3/8.9.3) with SMTP id WAA00567
for <murphy-rebel@dcsol.com>; Mon, 29 Mar 1999 22:24:41 -0500 (EST)
Message-ID: <005001be7a5c$aaa6f180$a9eaa1d1@ns.idirect.com>
Subject: Re: bolt holes
Date: Mon, 29 Mar 1999 22:23:20 -0500
MIME-Version: 1.0
Content-Type: text/plain;
charset="iso-8859-1"
X-Priority: 3
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook Express 4.72.3110.5
X-MimeOLE: Produced By Microsoft MimeOLE V4.72.3110.3
Hi Neil. I drilled and reamed my bolt holes using "under" reamers. One place
to get them is www.kbctools.com. They will supply a huge tool catalog free
of charge.
The bolts went in snug, some needed a light tap with a plastic mallet. I
found slight variation in the bolt diameters which is to be expected from
plated parts.
Paul Kucera, 453R
To: Murphy Rebel <murphy-rebel@dcsol.com>
Date: Sunday, March 28, 1999 3:28 PM
Subject: Re: another question on epoxy etc.
Thanks for the comments, but I guess I didn't make myself clear. My
handbook of standard aircraft practise says that for a 1/4 inch bolt, the
hole can be up to 6 thousands oversize! In addition if you micrometer the
AN bolts you will find they have considerable slop, and average about 4
thousands undersize. As a result, a hole that is to be drilled to
1/4inch, micrometers at (say) .251 thousands... and the bolt that goes in
it is 4 thou under.. hence 5 thou of slop even in a close tolerance 1/4
inch hole. And my query was whether others had worried about this..
But I expect I am just being overly anal,... since the only solution is to
go to close tolerance bolts and reamed holes.
Oh, well, I will just go back to deburring.
Neil Humphrey
On Sat, 27 Mar 1999, Bob Patterson wrote:
Several thou. of slop sounds serious to me - it might be better to ream
to allow the next size larger bolt !
Any slop can cause greatly increased wear rates, and create major
safety problems quickly. I have seen flutter problems on gliders caused
by barely perceptible movement on control surface attachments !
Useing Epoxy on bolts is not a good idea, in any case, as the
adhesive
effect will make it difficult or impossible to remove the bolt -
which you will want to do for service !!
Best to talk to Kerry, at Murphy, about these sorts of problems -
a little time on questions now could save a lot of grief later !!
-----------------------------orig.----------------------------------
At 03:35 PM 3/26/99 -0700, you wrote:
By the time you have drilled through several layers of material, and
used
the resulting holes for drill guides for other holes, I sometimes find
that the resulting bolt holes are a couple of thousandths oversize.
This
isn't a problem for rivets, but there is sometimes a barely perceptible
slop on the inserted bolts. Anybody else worried about this enought to
do
something about it? Is the epoxy chromate strong enough as a gap filler
to fill a couple of thousandths of an inch... anybody out there with
thoughts? since I am sure others have worried about this.
Neil Humphrey
#371
