Tach Cable
Posted: Sat Feb 18, 2012 2:58 am
by Al & Deb Paxhia
Clay,
The way I did mine was to measure from the engine tach drive surface to the
tach and added 1". I did this using a wire to get all the bends and curves.
This gives a slight bend in the drive cable.
Al
Sent: Monday, November 10, 2003 1:26 PM
Subject: Tach Cable
Hi Guys,
I need to order a tach cable for my 0320 and checked the ACS catalogue
for the custom length order info. The instructions say to measure
original cable from each ferrule end. What's a ferrule? Would that be
the total length of inner cable including the metal keyed ends that fit
inside the gauge and engine ... ? The ACS order desk couldn't give me
much help. I figure that my cable will be around 18" with a slight 'S'
turn through the firewall. Maybe I should just go with a longer cable
with a loop ...? Any advice?
Clay Reb 475
Tach Cable
by Clay Smith
Hi Guys,
Clay Reb 475
Tach Cable
by Drew Dalgleish
Hi Clay
I think the ferrule is the part that is crimped onto the cable that the
nut runs on. If you measure from the engine flange to the back of the tach
you should be OK. Putting a loop in the cable isn't a very good idea the
cable will be noisy and probably not last very long.
At 01:26 PM 11/10/2003 -0800, you wrote:
Hi Guys,
Clay Reb 475
Tach Cable
My first cable was nicely the right length direct from tach to engine and a
nice new SW tach took care of that one, during the first hour when the worn
drive seized in the new tach. I have been running a 38" cessna cable that
has a nice large 360* loop, behind the panel, for 8+ years now (around
400hrs) and my tach is nice and smooth with no indications of the
cable/housing giving it up yet.
Sent: Monday, November 10, 2003 1:10 PM
Subject: Re: Tach Cable
Hi Clay
Hi Guys,
Clay Reb 475
Tach Cable
by Legeorgen
Clay,
Order your tach cable the full length including the ferrules that fit on each
end of the cable that insert themselves into the gage and engine. I wouldn't
loop it but make sure it is long enough to make the proper "s" turns without
sharp a bend.
Bruce
tach cable
Posted: Sun Feb 19, 2012 2:21 pm
by Jones, Michael
Hi all
Am ordering tach cable and am wondering if I should allow for some extra in
cable to allow for engine moving or just run it straight with as few bends
as possible
Mike#007
