metal preparation....
Posted: Fri Feb 17, 2012 11:58 pm
by Jean Poirier
I finally start construction (work table done, air line done, garage clean up done etc). All ribs (leading/trailing edge) are cleco to the ailerons ribs. Ready to desassemble, deburre, prime and reassemble with cleco and than rivet. Mam have send me some b/o of the original shipment but the Met-sol still b/o....... Can I use something else? In the past to repaint a Cessna elevetator, I have use top quality thinner with scothbrite. But this time it is very important because it is MY REBEL!!!! Car refinishing products or industrial, let me know....
Jean Poirier
Rebel 747R
Jean, just hit Canadian Tire or your local Hardware store and buy a couple
quart cans of Acetone.
Sent: Saturday, November 08, 2003 7:28 PM
Subject: metal preparation....
Jean Poirier
Rebel 747R
I assumed Jean was talking about cleaning the aluminum prior to any epoxy or
paint. If you were talking about thinning your paint Jean, disregard my
reply!
P.S. Dave, it's past your bedtime in NS!!!!
Sent: Sunday, November 09, 2003 12:13 AM
Subject: Re: metal preparation....
Jean
You should use a thinner compatable with the paint you will put on the
parts. If you do go with painting the parts and assembling them dry then
use a thinner compatable with your primer, if you use the polyfibre then use
the thinner for that product.
For what it is worth, we use a chromate carrying etching primer from
Duponts' automotive line called Corlar 810R and we clean with laquer thinner
before priming. Dupont advised Corlar was the best choice for our aircraft.
Corlar is the base primer for their Imron topcoat system.
We assembly dry, this is what Cessna does so it is good enough for us! We
do not prime the outside of the assemblies, we will do this when the plane
is finished and ready to paint.
Hope this helps, have at it & enjoy!
Dave R.
elite583.cjb.net
Jean Poirier
Rebel 747R
David A. Ricker
Fall River, Nova Scotia
Canada
Hey I took my wife out for supper at least tonight! Maybe, if I get offline
now, she's still awake!! ;o)
Besides, anything beats the family/relative burials I've been attending,
that's kept me off line this week.
Sent: Sunday, November 09, 2003 12:36 AM
I was speaking of cleanup prior to paint also, just figured that the
thinner for
the paint (or compatable) was a good idea for prep too, no issues of
compatability that way. Acetone is fine like Wayne said but I think
lacquer
thinner may be a little less costly and it also does a good job of
cleaning up
the ink from the material ID stamp..
P.S. Wayne, its' only an hour earlier in Ontario, what does that say about
your
Saturday night, night life? ;>)
epoxy or
reply!
Jean
then
use
thinner
aircraft.
We
plane
Dave R.
elite583.cjb.net
shipment
past
REBEL!!!!
David A. Ricker
Canada
David A. Ricker
Canada
by David Ricker
Jean
You should use a thinner compatable with the paint you will put on the parts. If you do go with painting the parts and assembling them dry then use a thinner compatable with your primer, if you use the polyfibre then use the thinner for that product.
For what it is worth, we use a chromate carrying etching primer from Duponts' automotive line called Corlar 810R and we clean with laquer thinner before priming. Dupont advised Corlar was the best choice for our aircraft. Corlar is the base primer for their Imron topcoat system.
We assembly dry, this is what Cessna does so it is good enough for us! We do not prime the outside of the assemblies, we will do this when the plane is finished and ready to paint.
Dave R.
elite583.cjb.net
Jean Poirier
Rebel 747R
David A. Ricker
Canada
by David Ricker
I was speaking of cleanup prior to paint also, just figured that the thinner for
compatability that way. Acetone is fine like Wayne said but I think lacquer
thinner may be a little less costly and it also does a good job of cleaning up
P.S. Wayne, its' only an hour earlier in Ontario, what does that say about your
reply!
Jean
Dave R.
elite583.cjb.net
Jean Poirier
Rebel 747R
David A. Ricker
Canada
David A. Ricker
Canada
by Bob Patterson
Hi Jean !
You can use plain acetone instead - it's the safest of a
bunch of choices. Much better than MEK or the like, but still
calls for lots of fresh air, and reduced skin contact (gloves).
A light rub with Scotchbrite won't hurt either ..
----------------------------------orig.-----------------------------
Jean Poirier
Rebel 747R
