rebel dimensions
rebel007r
rebel dimensions
Post by rebel007r » Fri Feb 17, 2012 11:58 pm
hi all
could some kind person give me a dimension from firewall to prop flange, need
to see how big a garage i need to finish my kit, its going to be close i
suspect
mike#007
rebel dimensions
Post by Mike Davis » Fri Feb 17, 2012 11:58 pm
Hi Mike, if I don't remember if you're building a Rebel or a SR/Moose... if
it's an SR/Moose we've got a picture showing the firewall forward dimensions
and thrust line on the archive site... click here:
http://rebel:builder@www.dcsol.com:81/f ... age002.gif
It shows "front of hub flange to firewall vertical rivet line" as 45 3/8".
Sent: Thursday, November 06, 2003 11:25 AM
Subject: rebel dimensions
hi all
need
suspect
mike#007
Murray Cherkas
rebel dimensions
Post by Murray Cherkas » Fri Feb 17, 2012 11:58 pm
About 21'4". Don't forget you also have to put the spinner on but not till
later.
Murray
rebel007r@dcsol.com
Sent: Thursday, November 06, 2003 1:26 PM
hi all
need
suspect
mike#007
apoulsen
Rebel dimensions
Post by apoulsen » Sun Feb 19, 2012 10:47 am
Hi all,
I'm working in very tight space (10' X 13') and would like to delay renting a largeer space as long as possible.
I would like to know if someone can give me the length of the fus from firewall to the solid bulkhead just before the tail wrap. Also would appreciate opinions on whether I would be creating problems for myself if I built this part of the fus and then came back to add the tail cone and tail later.
Thanks in advance.
Allen Poulsen
786R
