primer.... part 2...
Posted: Fri Feb 17, 2012 11:58 pm
So when I am ready to final assembly, I just prime (with epoxy primer) using a brush the joint to be assemble? Balance of the ribs, skins, gusset, small parts, ect stay bare? If I decide to prime as an exemple the inside of wings parts/skin, I may be can spray the parts, let them dry and then brush the joints to be assemble or it is too fancy? Cleco do not suffer from the wet primer?
When you prime the rivets, do you dipped down to the top of the head (what a mess on the rivet gun) or just the mandle up to under the head? With the chemical kit I have received from mam, the polyfiber primer reducer is not included, it is probably better to find the original thinner or if you use others epoxy thinner (let me now which one). Do you add thinner for the rivets dipping, and for brush use or only when you spray it?
I know I have a lot of question that probably sound very basic and may be "borowing" ( don't asked me to spell that word!) but it is may be the only aircraft I will have the chance to built and I want as less as possible "regrets" after it will be done...
Thanks to every one
Jean
Rebel 747R
Thanks to every one
Jean
Rebel 747R
