another question on epoxy etc.
Posted: Fri Feb 17, 2012 8:18 pm
Received: from asuwlink.uwyo.edu (asuwlink.uwyo.edu [129.72.60.2])
by ROPER.UWYO.EDU (PMDF V5.2-32 #33749)
with ESMTP id <0F980090W42DRW@ROPER.UWYO.EDU> for murphy-rebel@dcsol.com;
Fri,
26 Mar 1999 15:35:01 -0700 (MST)
Received: from localhost (neil@localhost) by asuwlink.uwyo.edu (8.8.8/8.8.7)
with SMTP id PAA16890 for <murphy-rebel@dcsol.com>; Fri,
26 Mar 1999 15:35:00 -0700 (MST)
Date: Fri, 26 Mar 1999 15:35:00 -0700 (MST)
Subject: another question on epoxy etc.
In-reply-to: <199903262221.KAA09031@callisto.net.voyager.co.nz>
X-Sender: neil@asuwlink
Message-id: <Pine.GSO.3.96.990326152833.3485E-100000@asuwlink>
MIME-version: 1.0
Content-type: TEXT/PLAIN; charset=US-ASCII
X-Authentication-warning: asuwlink.uwyo.edu: neil owned process doing -bs
By the time you have drilled through several layers of material, and used
the resulting holes for drill guides for other holes, I sometimes find
that the resulting bolt holes are a couple of thousandths oversize. This
isn't a problem for rivets, but there is sometimes a barely perceptible
slop on the inserted bolts. Anybody else worried about this enought to do
something about it? Is the epoxy chromate strong enough as a gap filler
to fill a couple of thousandths of an inch... anybody out there with
thoughts? since I am sure others have worried about this.
Neil Humphrey
#371
Fri,
MIME-version: 1.0
Neil Humphrey
#371
