from two separate side vents just below the motor mounts. The heat is not a
problem now that the interior is installed. Prior to installing the interior
and insulation it was very cold inside with heat and defrost going full
blast ( -10F outside +10F inside).
Al
Moose, N526AP
Sent: Saturday, October 18, 2003 11:29 AM
Subject: Moose Cabin Heat Box
theHey Guys,
1) What have you guys that are flying installed for cabin heat ? We have
AnyM-14 with dual heat muffs.
2)Any consideration in the cabin for rear passenger heat and/or defrost ?
3)Separate hot air and separate cool fresh air versus a box that mixes.
*-------------------------------------------------------------------------*comments ?
4) Advise any fresh air venting hardware that has been found to work well.
Thanks for the feedback in advance.
Randy Bowers Moose 130
