Fuel line fixation front
Post by Mike Davis » Fri Feb 17, 2012 5:18 pm
Received: from fwd06.btx.dtag.de (fwd06.btx.dtag.de [194.25.2.166])
by mailout05.btx.dtag.de with smtp
id 10Nl4A-0001a5-00; Thu, 18 Mar 1999 23:15:02 +0100
Received: (068612707-0001(btxid)@[193.159.7.189])
by fwd06.btx.dtag.de
id <m10Nl41-0003F9C>; Thu, 18 Mar 1999 23:14:53 +0100
Message-Id: <m10Nl41-0003F9C@fwd06.btx.dtag.de>
Date: Thu, 18 Mar 1999 23:14:53 +0100
Subject: Fuel line fixation front
X-Mailer: T-Online eMail 2.2
MIME-Version: 1.0
Content-Type: text/plain; charset=ISO-8859-1
Content-Transfer-Encoding: 8BIT
X-Sender: 068612707-0001@t-online.de
From: Johannes.Laubenthal@t-online.de (Johannes Laubenthal)
Hallo Rebel Group!
Any comments on fuel line fixation in front sidewalls ( left and right sides
behind the firewall).My Fuel lines pass through the Uprigts . I do not want
drill rivet holes for grommet brackets in the lower corner wraps . I
installed
the .032 " corner wraps but I fear that rivet holes could weaken this
stressed
areas .
Furthermore I think of installing a fuel flow measure. ( Electronics
International FP 5 ?) Best location for the fuel flow transducer below the
T-
pipe and before the gasculator??
Johannes Laubenthal R 603
Received: from [137.186.228.101] (helo=ms02-355.tor.istar.ca)
by mail4.toronto.istar.net with smtp (Exim 1.92 #2)
for murphy-rebel@dcsol.com
id 10OCLE-0000nz-00; Fri, 19 Mar 1999 22:22:28 -0500
Mime-Version: 1.0
Subject: Re: Fuel line fixation front
Message-Id: <E10OCLE-0000nz-00@mail4.toronto.istar.net>
Date: Fri, 19 Mar 1999 22:22:28 -0500
With the .032 corner wraps, a couple of rivets are unlikely to cause
you any problems, Johannes !
Perhaps you could make small metal loops, rivetted to the floor panel
in the front, at the edge, to support the fuel lines, if you are really
worried .....
------------------------------orig.----------------------------------
At 11:14 PM 3/18/99 +0100, you wrote:
Hallo Rebel Group!
sides
installed
stressed
areas .
the T-
