Elevator Trim - Was Rebel Flaperon Control System
Posted: Fri Feb 17, 2012 11:50 pm
Wow, Bobp, you had a second flutter incident on your
Rambles!!?? You told us out west here about the one
that happened over Manitoba. That was scary enough.
This additional talk about runaway trim failure also
has me wondering whether it is even worth having an
electric elevator trim. I never adjust trim on mine in
flight anyway, as it seems to have the same control
pressure whether in climb, cruise or any throttle
setting. A ground adjustable one would work fine. The
only possible reason would be as a back-up to your
elevator cable if it broke.
Archives located at
http://www.dcsol.com:81/public/code/html-subscribe.wcx-----Original Message-----
[mailto:mike.davis@dcsol.com]On Behalf Of Bob
Patterson
Sent: Saturday, September 13, 2003 7:54 AM
Subject: Re: Rebel Flaperon Control System
Hi Ken !
I'd appreciate it if you could find
that bulletin - and
a web address for it, if you have it.
I'll be talking about this, and a
couple of other areas,
at the Builders Meeting on Sunday - these
are NOT "nice-to-do" things,
they are ABSOLUTELY NECESSARY !!! (still
shaking !! :-( )
Bruce only heard about the
partially-broken (by a stone
on takeoff) trim tab horn - the
'field-repaired' one tore completely off
over New Brunswick, and I payed an
unscheduled visit to Mr. McCain's
private runway !! Sure glad it was close !
Thanks ! See you all on Sunday !
--------------------------------orig.--------
At 10:56 PM 9/12/03 -0400, you wrote:the trim horn on all 0-320 trimBruce
There is indeed a MAM bulletin to doubleregardless of engine. I cantabs and also recommending it on all RebelsI believe.look it up but I've had it for a few yearsthose channels to tie into theRoger
FWIW I used angle brackets at the rear offloor channels. I think that isbulkhead. Same as on the ends of all thethough that it is a busywhat they mean by gussets. You are correctbulkhead over the cutout in thearea. There is a doubler there on thedoubler over the cutout on thetop of the bulkhead. I replaced thatarranged for some of thebulkhead with a much larger doubler. Then Ithe angle brackets. If Isame rivets to fasten both the doubler andthe rivets in the doubledremember correctly, you should also offseteach other in the gap betweenbulkhead so that they don't interfere withthose doublers don't drillthe doubled bulkheads. ie. when installingrivet from the rear would thenstraight through both bulkheads as thechannel between bulkheads now as ainterfere with the rivet from the front.
Legeorgen@aol.com wrote:Wayne,
The newer manuals (CD) DO show this
doublepondered doubling mine butchannel. I looked at this last year and
decided itmentioning he lost his electric trim tapwas not worth it.
I do remember Bobp at Arlington
hornOn landing it was noticed the singlein flight and had a flutter experience.tap on newer models) had failed. Ihorn on the trim tap (now a double trim------------------------------*would double this area if anyone hasn't yet.
Bruce 357R
*-------------------------------------------To unsubscribe from this list go to:
http://rebel:builder@www.dcsol.com:81/default.htmArchives located at
mike.davis@dcsol.comTo contact the list admin, e-mail
Archives located at
