Rotax V300T HP?
Rotax V300T HP?
Post by Mike Davis » Fri Feb 17, 2012 11:28 pm
This is true, but they are getting hundreds of thousands of miles out of
Subarus producing this kind of power with their engines. As already pointed
out, the new WRX is getting 300 HP out of a 2.5L. The Subaru WRX is one of
the only cars running the world ralley championship circuit that can run an
entire season without an engine rebuild. It will be very interesting to see
how the new Bombardier works out in the field.
In the R/C aircraft world it's not uncommon to get 2 HP from .5 cubic inch
engines... I've got one that has survived 7 different airplanes over the
course of as many years... still runs strong.
Sent: Thursday, August 21, 2003 7:49 PM
Subject: RE: Rotax V300T HP?
I'm not a techi or mechanic. I did read Ricard Finch's book. A 2.2 L.
Honda
can put out 800hp. A mercedis benz can also put out 800 hp. at 14000rpm.
This engine has a TBO of 5-10 hrs.Seems to me the more you want from an
engine over and above the original design parameters the quicker the
engine
gets used up.
Think about it
Murray
LisaFly99@aol.com
Sent: Thursday, August 21, 2003 7:34 PM
Subject: Re: Rotax V300T HP?
In a message dated 8/20/03 10:23:07 PM Central Daylight Time,
mike.davis@dcsol.com writes:
For a long time I've been very interested in the 3.3L Subaru engine, but
one hang up almost everyone has when I talk to them about this engine is
that 320 HP out of a 3.3L engine is just to much power to expect out of
an
engine that size. I find it interesting now to see Bombardier come out
with
their V300T engine that displaces 189 ci... or 3.096954L.
All the claims and reports are that they built this engine from the
ground
up with aviation in mind, and did extensive computer modeling to ensure
reliability. I wonder if as these engines start flying and building
hours
if they will successfully change peoples perceptions regarding how much
horse power you can wring out of a modern engine.
MIKE
That all depends if you're OLD school or NEW school. And how bullheaded
you
are...
Phil&Lisa Smith
#460R
N414D
Murray and Carol Cherkas
Rotax V300T HP?
Post by Murray and Carol Cherkas » Fri Feb 17, 2012 11:28 pm
I'm not a techi or mechanic. I did read Ricard Finch's book. A 2.2 L. Honda
engine over and above the original design parameters the quicker the engine
gets used up.
Think about it
Murray
LisaFly99@aol.com
that 320 HP out of a 3.3L engine is just to much power to expect out of an
with
All the claims and reports are that they built this engine from the ground
reliability. I wonder if as these engines start flying and building hours
MIKE
That all depends if you're OLD school or NEW school. And how bullheaded you
are...
Phil&Lisa Smith
#460R
N414D
LisaFly99
Rotax V300T HP?
Post by LisaFly99 » Fri Feb 17, 2012 11:28 pm
engine that size. I find it interesting now to see Bombardier come out with
MIKE
are...
Phil&Lisa Smith
#460R
N414D
