PSRU Adapter
PSRU Adapter
Post by Mike Kimball » Fri Feb 17, 2012 11:28 pm
I received my PSRU to engine adapter yesterday. I am disappointed in the
quality of the casting. On one side there is a large void, like a little
cave in the casting. And there are pinholes everywhere which may be
permeated throughout the casting internally where I can't see it. Indeed,
there could be large voids similar to the one I can see. Another sharp
angled void is present on one of the edges that would certainly be a stress
riser. I was also surprised it was cast. I expected a machined part. The
website says that the gear case is machined from 6061-T6 billet stock. I
assumed the adapter would be too. Is it possible it was and the voids were
present in the billet? I don't know anything about how billet stock is
created.
SR #044
Bill Delcambre
PSRU Adapter
Post by Bill Delcambre » Fri Feb 17, 2012 11:28 pm
Well Mike,
Not being an engineer or metalurgist, I'll give you my opinion, as
developed from too many years of dealing with welding of aluminum. Billets
are the result of rolled or forged ingots. The material is dense and clear
as a result of the mechanical working that makes it a billet. Voids or
pinholes would be extraordinarily rare. Castings are produced by pouring
the molten metal into molds and then final machined from the result. Not
only are castings inherently porous, as a result of trapped gases during the
cooling process (pinholes) but the alloys used for casting are not quite the
same as those from which the billets are produced. In welding, you'd be
amazed how porous aluminum castings are, even really good ones. Aircraft
cylinder heads, for example, are castings. They're good ones, but have more
porosity than you'd imagine. Doesn't seem to be a problem. If it's
machined from billet aluminum, you won't see any voids or pinholes. If it's
a casting, what you've described is not surprising, to me. There's a lot
more differences between castings and billet items, as I'm certain will be
described by those more knowledgable than me, but bottom line is your
confidence in the manufacturer. As stated, cylinder heads are castings and
work just fine. Properly designed, nothing at all wrong with a good
casting.
Bill Delcambre
stress
The
were
created.
SR #044
Rickhm at home
PSRU Adapter
Post by Rickhm at home » Fri Feb 17, 2012 11:28 pm
Mike,
I design medical equipment for a living. As such we rarely run into the
forces that an engine go through, but if we need a strong part we cut it
out of a billet. With casted parts there is a "grain" that is formed by
the flow of the aluminum. BIllet stock typically is viewed as not having a
grain. I'm sure it does, but there isn't a sense of grain due to the
issues that Bill mentioned, i.e. rolling etc. I would make a phone call
and ask them how many of the cast parts are operational in the field and
what their history is! As I have looked for my PSRU I have tried to avoid
both welding and castings. Bill does make a good point that many parts are
made from castings and I have seen good strong castings made. But given
the forces involved I think you need to ask more quesitons, to be sure!
Hope it works out, surprises are never fun!
Rick
From: Bill Delcambre [SMTP:bdelcambre@cox-internet.com]
Sent: Thursday, August 21, 2003 3:32 PM
Subject: Re: PSRU Adapter
Well Mike,
more
it's
casting.
Bill Delcambre
Indeed,
stress
The
were
created.
SR #044
*** File "WINMAIL.DAT" has been uudecoded and attached to this message.
larry173
PSRU Adapter
Post by larry173 » Fri Feb 17, 2012 11:28 pm
Where did you get the PSRU and what are you putting it on.
Sent: Thursday, August 21, 2003 4:54 PM
Subject: PSRU Adapter
stress
The
were
created.
SR #044
rickhm
PSRU Adapter
Post by rickhm » Fri Feb 17, 2012 11:28 pm
Mike,
I checked this AM with one of our Mechanical Engineers. He is also a car racer and rebuilds his engine about every 20 hours because they are run so hard.
I was close. There is actually very strong grain in billets. The process of rolling and forging creates a very dense strong structure. At times the grain in the billet will be use to the advantage of the part design for strength. Castings can be just as strong, but require more metal. When they make a crankcase they first cast it and then forge it by heating and applying extensive pressure. In the case of an engine block they will get it red hot and then somehow pound on it to "forge" the metal. I shared your observations about your PSRU casting. He agreed that the pockets and bubbles are cause for concern. The key question is does the casting have the same or more metal as its predecessor part that was cut from a billet.
Hope this helps.
Rick
-------Original Message-------
Sent: 08/21/03 06:31 PM
Subject: RE: PSRU Adapter
Mike,
are
Rick
Well Mike,
Billets
clear
more
it's
casting.
Bill Delcambre
little
Indeed,
stress
The
were
created.
SR
#044
message.
PSRU Adapter
I thought one comment from Rick was interesting. Mike Davis and I both
thought that my block was cast due to the rough surface where it was pulled
out of a mold. Yet I was always under the impression that Rodec blocks were
forged. If what Rick says is true, apparently it is cast first, then
"forged" (pressure and heat) which would explain why my block and my heads
don't have pinholes or voids anywhere, yet they have rough casting mold
release areas that make it look like it was a casting.
SR #044
rickhm@mindspring.com
Sent: Friday, August 22, 2003 10:09 AM
Subject: Re: RE: PSRU Adapter
Mike,
hard.
Hope this helps.
Rick
Mike,
are
Rick
Well Mike,
Billets
clear
more
it's
casting.
Bill Delcambre
little
Indeed,
stress
The
were
created.
SR
#044
message.
David Stroud
PSRU Adapter
Post by David Stroud » Fri Feb 17, 2012 11:28 pm
Who manufactured this adapter and what engine / PSRU is it for? Thanks.
Dave Stroud, Ottawa, Canada
Christavia Mk 1 C-FDWS
Fairchild FC-2 early construction
Sent: Friday, August 22, 2003 2:08 PM
Mike,
billet.
Hope this helps.
Rick
Mike,
are
Rick
Well Mike,
Billets
clear
more
it's
casting.
Bill Delcambre
little
Indeed,
stress
The
were
created.
SR
#044
message.
PSRU Adapter
Post by Wayne G. O'Shea » Fri Feb 17, 2012 11:28 pm
Hey, who let this guy on the list??
JUST KIDDING DAVE!
Sent: Friday, August 22, 2003 12:47 PM
Mike,
billet.
Hope this helps.
Rick
Mike,
having
avoid
are
Rick
Well Mike,
Billets
clear
pouring
Not
Aircraft
more
it's
lot
be
casting.
Bill Delcambre
little
Indeed,
sharp
stress
The
were
is
created.
SR
#044
message.
David Stroud
PSRU Adapter
Giday, Wayne. I joined the list with the view to start a Moose for use with the 285 hp Housai engine.
I was going to call it a Moose Lite..
I emailed Murphy for info but they could not reply as they were at Arlington, then they got too busy with Oshkosh.
Still nothing so I started the Fairchild.
Sent: Saturday, August 23, 2003 7:18 PM
JUST KIDDING DAVE!
Mike,
billet.
Hope this helps.
Rick
having
avoid
are
Rick
Well Mike,
Billets
clear
pouring
Not
Aircraft
more
it's
lot
be
casting.
Bill Delcambre
the little Indeed,
sharp
stress The I were
is
#044
message.
PSRU Adapter
I hear your disappointment Dave!
We are all starting to wonder what's happening on the "West Coast" as even
the "old" dedicated bunch aren't getting responses (or parts) either!
:o(
Sent: Sunday, August 24, 2003 2:58 PM
JUST KIDDING DAVE!
Thanks.
crankcase
will
casting.
metal
billet.
cut it
formed by
having
call
avoid
parts
given
sure!
as
or
pouring
Not
during
quite
you'd be
Aircraft
have
If
lot
will
be
your
castings
in
be
sharp
part.
stock.
voids
stock
is
