wing tip attach
Posted: Fri Feb 17, 2012 11:28 pm
I'm sure most will tell you here to make them removable
with rivnuts or some kind of anchor nuts with screws.
However, in my case, by the time I got to attaching my
wing tips, I decided I had sufficient practice and
skills at drilling out rivets, so I just went the quick
and easy route, and riveted them on. So far no regrets.
Murray and Carol Cherkas
Sent: Sunday, August 17, 2003 8:41 PM
Subject: wing tip attach
Hello All
What is the best way to install wing tips?
Of course I have already drilled
all the holes as shown for riveting.I've
also got wingtip lights which may
require removing the tips at some point in
time.Should I use self tapping
screws? To rivet floating riv nuts would be
a big job,clip nuts may work for
one wing but the flange on the other is the
wrong way.
Advise me please.
Murray
cribe.wcx
Archives located at
