Gascolator Primer Outlets
Post by Wayne G. O'Shea » Fri Feb 17, 2012 11:15 pm
I believe I promised to look at the Andair Gas500 Gascolator I have here and
post what I found. The Andair's primer outlet spot >IS< after the screen.
The ACS models of gasolator have the primer outlet on the unscreened side of
things.
Was thinking an easy "fix" for the ACS is to solder a fine mesh screen onto
the fitting being threaded into the primer outlet port, or put the fitting
in and then cut and press fit one to the area from the inside.
