for murphy-rebel@dcsol.com
id 10AEZ4-0006z3-00; Tue, 9 Feb 1999 09:55:03 -0500
Mime-Version: 1.0
Subject: swing up doors
Message-Id: <E10AEZ4-0006z3-00@mail2.toronto.istar.net>
Date: Tue, 9 Feb 1999 09:55:03 -0500
On the swing-up doors -
If you get some extra square door frame tubing, it can be fitted
inside the original frame (don't cut the top of the door), and this will
give you swing-up windows. A few builders figured that was too much work -
believe me, you'll want those windows !!
It's then just a case of move the hinges to the top of the window,
and the top of the door, and add an air shock strut from a car rear
window.....
You may have to change the shape of the bottom front of the
door slightly, to clear the strut - this usually only means bringing
it back an inch or so, and sharpening the curve a bit ....
Curt can give you more details ...
----------------------------orig.---------------------------------
At 09:45 PM 2/8/99 EST, you wrote:
ofI'd have to concur with Bob P's comments on Met-All. We used to polish
DC-3's, 6's and Convairs in the Marines with the stuff. Lasted the longest
somethingany of the stuff we tried. That's why everything on our Rebel will be
painted.
Lonnie: The "gear fix" is where I'm at right now...along with doing
thealong the line of Curt & Bill's mod for the swing-up doors. Are most of
sendfolks putting the larger engines, i.e., 0-320's & Subaru's doing the .032
corner wraps? Any other mods on the front?
Brian: We got a 'profile' to work on the paint scheme from Murphy. I can
sumpsit.
Those folks on floats...are the Murphy recommended positions of the fuel
of aadequate? Not being a float pilot yet is there a better position on the
fuselage for the Transponder antenna then under the cabin belly...outside
top mounted antenna?
Paul & Peg
S/N 374
